Thread: ThermalTech Core X9 vs Corsair Air 540 vs V71 , which is best for water cooling 3 Gpu?
    Default ThermalTake Core X9 vs Corsair Air 540 vs V71 , which is best for water cooling 3 Gpu?
    Hi guys,
    Just wanted to pick your brain a little about which case I should go for. I am planning to water cool my hackintosh based 3 Gpu (not in SLI) which will be the core of my octane GPU based render farm. Now if I water cool my cards, I will get a massive 30-40% boost in speed. Now I need a case that will have plenty of room for airflow even after all the water cooling parts. Would love to have a 900D or a caselab ST10 but I have three choices within my budget:
    1. X9
    2.Air 540
    3. V71.
    540:
    I really like the air 540 because the right side will take care of psu (I may have to add another one later) and cable routing and the heat dissipates to the right or at least to the top of right side. Problem is, it is quite small. To current users of this case, it may look big but once you try to put in everything, (3/4 cards, water cooling) it gets cramped in there. I am currently having a mail-conversation on few people on youtube and they said you gotta pick the parts really carefully caz every mm maters inside that case.
Name:	Screen Shot 2015-03-23 at 2.03.27 PM.png
    X9
    I am being told over and over again that its a case modders dream. But I am looking for simplicity and ease of use as well as functionality. Now the case looks big. But I am finding it difficult to see any good example of a build that I like. I have seen this but I don't like how the Psu is on the bottom. I would have moved it to right side and I am not planning removing all the hdd bays. I will put my ssd and just one hdd somewhere and save cluster to ensure airflow. I dont use dvd drive.
Name:	Screen Shot 2015-03-24 at 7.31.45 AM.png
    V71:
    I find this one the most specious. But I prefer compartmentalisation of heated parts and cable like 540, or even x9 more than this one tower kinda setup. May be using a simple plate to separate the psu like in 900D? I would much like it if the psu was on top end rather than the bottom.
    help, suggestions, rants everything welcome brothers. As I am going to get his sorted very quick Inshallah.
    Wassalam.
    • TaherTheRetard's Gadgets
      • CONSOLE MASTER RACE
      • 136
    Khilgaon
    I suggested you the core x9 at gaming gear :v
    You can fit the biggest available radiators in this thing. What else do you want ?
    Modded v71 https://www.facebook.com/permalink.p...62236020510911
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    Quote Originally Posted by কায়েস View Post
    540: To current users of this case, it may look big but once you try to put in everything, (3/4 cards, water cooling) it gets cramped in there
    I think i am the only idiot here with that case
    You could always put the water cooling kit in the second chamber. There are plenty water cooling mod tutorials doing that with that case on YouTube.
    Where did you find "ThermalTech"???
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Eigula dokan er vitorer warehouse e paben. kokhono display te thake na :3
    • Mahib's Gadgets
      • ASUS Maximus VII Ranger
      • Intel core [email protected] & Corsair 450D casing
      • Team xtreem 1X8GB 9-9-9-24 +G.Skill Value 1X8GB 1600 11-11-11-28
      • Crucial MX200 250GB+Samsung 320GB+Toshiba 650GB+ Macbook pro retina 2013+ HP Pavilion g6-2006TU
      • MSI GTX970 Gaming [email protected] + [email protected]
      • Acer H226QLbid + Asus VX229H - Both 60Hz IPS 1080P display
      • ROG Supreme FX
      • SONY DAV-TZ-140 Home theater
      • Ttesports Poseidon Z Blue RGB
      • Ttesports Talon + Steelseries Sensei
      • Logitech F310
      • Cooler Master V550W
      • DOn't have one any more
      • WD 1TB USB 3.0 + ADATA 32GB USB 3.0 + Transcend 16GB USB 2.0 + ADATA USB 3.0 8GB
      • Nope + HUntkey PZB 504
      • WIndows 7 Home premium(HP) + Windows 8.1 pro (not geniune) + Korora(Dual boot PC) + Mac OS X 10.9.5
      • Don't do much benchmarking
      • Nope nothing to comment as it is always upgrading ;)
      • Antaranga Dot Com
      • 6Mbps
      • 6Mbps
    Mahib's Avatar
    Feb 2015
    Core x9 for MOD. It will meet ur needs and even more.
    But I would rather have the Air 540 among this three. ( No particular reason, I just like the looks better )
    Quote Originally Posted by Syeef View Post
    You aint the only one bro. man, I like that case very much because of its innovative efficient design. I might even end up buying that one for monetary reasons. computersource takes my card and will give a 6 month 0% EMI so I can get like 50k worth of stuff. Thats how they have been selling their overpriced stuff to me!!!
    I have been thinking about putting the cooling kit in the second chamber. It just having a lot of room is always nice even when you watercool. I would like to have my air cooling going on as well as water cooling with one big rad. Some experts in my field (octane's gpu-based rendering) are going to extreme measures.One of them suggested an external rad. This is what he said :
    I'm coming with article about external watercooling soon =) where I'm going to list some great options.. but jsut to give You an idea =) something like this Aquacomputer rad with integrated d5 pump would work great =) Yeah, You're probably need more than that, but..having pump/res rad in one unit You can save on all the fittings & thus minimise leaking problems too =) quick disconnects on the back of that case should do the work if You need to transport Your rig - so basically what You left is waterblocks inside, & maybe a rad in You rig "
    his name is tom glimps.
    I could put that in the second chamber I guess
    Thanks man...I have been using that all around internet making me look like a fool. Ah well.
    Quote Originally Posted by Gentleman View Post
    hey cheers bro. I am seriously thinking of this case because of the expandability options it provides. What I like about it is radiator support and it is big!! Costs so little as well! Also I like the stacking options. If I get this, I can see myself stacking a smaller x2 later (if that is possible) or even another x9. This would become a dream if I could move the motherboard tray vertically and divide the case not horizontally but vertically making this case a superior air 540.
    Could you please give me some links who have modded it? Mind you that my needs are for performance, not gaming or aesthetics.
    Thanks. I did take your advise though. That is why it is on my list!!
  1. Available water cooling productrs for graphics card
    By outragedhuman in forum Help - PC Buying
    Last Post: December 9th, 2013, 20:18
  2. Want to Buy Corsair memory cooling & monitoring
    By Speed in forum Shop - Gadgets
    Last Post: September 1st, 2013, 02:30
  3. Replies: 2
    Last Post: September 14th, 2011, 21:02
  4. Replies: 3
    Last Post: August 15th, 2011, 17:34
  5. Water Cooling Pump (not Pedrollo ones u dummy!)
    By minitt in forum Others PC Hardware
    Last Post: February 22nd, 2009, 01:23
Page generated in 0.20827 seconds with 15 queries.
