Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 50
Thread: Suggestion for Buying LCD/LED Monitor
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5" 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Lightbulb Suggestion for Buying LCD/LED Monitor
    ok guyz its been a while that i am planning to buy a new Monitor and finally i have decided to buy it at the starting week of the december, hopefully..
    I am using Samsung Syncmaster 591s since 2007, this is a CRT monitor. So I haven't actually experienced any LCD/LED monitor that much, infact i dont have a crystal clear idea on the features and facts that i need to focus while buying and LED/LCD. So i need help from u guyz. i need a thorough suggestion on buying an LED/LCD monitor from u people.
    i am providing necessary infos and questions u need to know to make the Suggestion..
    • At first u guyz need to consider my Rig, which u can see under my username. consider my GPU, Processor etc stuffs.
    • My Budget is Maximum 10K
    • i am not really a Max out type of gamer. i am happy if a game runs smooth on my PC with medium graphics details.
    • i am not a big fan of huge size monitors. infact i would not go beyond 18.5", and could i be able to run most games atleast with Mid GFX details in 18.5"? what do u think?
    • LED or LCD? which one to choose?what is the big deal with the LEDs?
    • wide or square? i mean why the price of square monitors are high? what is the difference? more importantly which one is better for Gaming?
    • do the LCD's have any heat issue? like heating up if used for longer period of time, i m not sure about it, just asking as i heard it from my friend.
    • another major question, which brand to go for? for LED and for LCD..
    • and also consider facts like Response time, Contrast Ratio (is it the more, the better?) , viewing angle etc
    • and also take note of any other extra features, which are necessary
    ok at the momment i have these, now guyz give me some advice, which monitor should i go for? give me some model name, and plz explain why you are recommending those.
    Thanks in advance for your help..
    P.S. atm i have these questions and facts to know, but i might gonna add some questions and facts later..
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Default Re: Suggestion for Buying LCD/LED Monitor
    Your rig is almost same as that of mine except for the ram and i can play most of the recent games in high settings. as you can see i am using a 20" LEd samsung before that i was using a 20" LCd samsung and i can easily see the color and contrast difference....LEd one has a lot better colour and contrast(I compared them side by side in my home)... So its upto u now to decide--
    The choices are----
    1. 18.5" LCD samsung B1930 5ms ---8300tk
    2. 18.5 LED samsung BX1950 5ms ---10200tk
    3. 20" LCD samsung B2030 5ms ------9600tk (used for 4months before buying the LED)
    4. 20" LED samsung BX2035 2ms -----12200tk (currently using this for last 4 dayz)
    Answers to the questions----
    1. Off course widescreen best for moviez and gaming....Square ones are good for office uses.
    2. LEDs have better colour depth and contrast.
    3. The screen may heat up slightly but its negligible.
    4. Response time matters in gaming the lesser the better.
    5. Contrast ratio the greater the better.
    Hope this helps...
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Good explanation...i think d last 1 with 2ms response time would be better.what do u think?
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    @abhi4168 thanx man for your well explained suggestion.. yeah we both have almost same Rig..and i am hopefully noching up my RAM to 4GB on jan 11.. acoording to your suggestion 18.5 LED samsung BX1950 looks good to me, but before going to any conclusion i want to chk out some other brands like Phillips, Asus, HP etc.
    So guyz feel free to give me some suggestions about any other brands and any thing if you would like to add..
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^^after shifting from crt 2 lcd everything will be fine except response lag...i hav a crt monitor.comparing 2 a 5ms lcd it is noticable .specially in gaming...and before buying make sure that it hav d native res. in which u wanna play...
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    @Mohiuddin sorry i dont get it..make it clear..
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    he meant that if u buy the 18.5 ones which has a native resolution of 1366x768 then the game will look best in that resolution...
    for example if u buy a hd monitor(native 1920x1080) and then play at 1366x768 or some other the game may not look good..
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    Quote Originally Posted by SadIkMahdI View Post
    almost all lcd monitor having 1 native res. nd widout that res. it cann't display other res. clearly...but crt don't hav such issue.
    • Arif69's Gadgets
      • Gigabyte H61 S2P B3
      • Intel Core i3 2100
      • Dell E1910H 18.5 Wide Lcd
      • VIA HD Audio Codec
      • Lexma LK7550P Slim
      • Logitech B100
      • Generic Usb Joystick
      • ITS 500 Watt
      • Samsung SH-224BB 24X
      • Transcend Jetflash350 16 GB
      • KS
    Talking Re: Suggestion for Buying LCD/LED Monitor
    Atlast you have come to a decision that you will change your monitor .
    • Quote Originally Posted by SadIkMahdI View Post
      i am not really a Max out type of gamer. i am happy if a game runs smooth on my PC with medium graphics details.i am not a big fan of huge size monitors. infact i would not go beyond 18.5", and could i be able to run most games atleast with Mid GFX details in 18.5"? what do u think?
    You will be easily able play old/new games in that settings.But if you upgrade your GPU you will be able to play in higher settings .
    It has better contrast,takes less power,makes less heat.So why not LED .But AFAIK there is not that much of good LED monitors yet available in BD :S.
    Wide wide wide .Wide is more enjoyable,comfortable in watching movies & more fun in playing games.Square monitors price is high because IMO those models are old ones & those are for office use.That's why maybe :S.So go for wide ones .
    I haven't faced this kind of any prob in my monitor yet .Also its not a big issue.
    I personally don't like Samsung (vai kew rag koiren na :S).Except that go for any other brand .
    It would be best to choose monitor with 2m response & with higher contrasts,viewing angle (but sometimes it may vary between different brands),I have found a good link about this things, you may look at this - http://www.lagom.nl/lcd-test/
      You should check before buying whether there is HDMI port,DVI port,speaker is available or not.
    I haven't gone to market for last few days.So right now I cant give you any suggestion about which model to choose :S.
    Quote Originally Posted by abhi4168 View Post
    Also those are the exact resolutions (1366x768) for 18.5 monitors.
    I am not expert in this but hope my words has helped you.And sorry if i have made any mistake :S & correct me if am wrong.
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^+1.LED is better than lcd.but LED screens r a bit shiny than lcd which coz problems sometimes i think.(correct me if i m wrng)
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    no LED monitor screens are same as that of LCds but LED Tvs screens are a bit shiny
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^vhai,can u explain why led tv is shiny where led monitor is not?.....just wanna know.
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    I dont know the reason..but i saw some samsung and sony LED tv havind a bit shiny screens
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    In which , black contrast is better?
    ---------- Post added at 21:30 ---------- Previous post was at 21:28 ----------
    Nd i saw some asus led monitor a bit shiny.
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    @Arif69 thanks a lot man for answering all my questions patiently..
    Quote Originally Posted by Arif69
    hmm..but akhono amar ageer monitor ta akhono flawless performance ditese..joss ekta monitor..
    i get it now
    amar kaseo normally dokane LED and LCD dekhe tamon kono difference mone hoy nai
    hmm akhon LED ee nibo and 18.5 ee nibo but brand konta bustesi na..dekhi net a ghataghati kore..phillips er ekta monitor dekhlam
    Philips 191EL2SB
    Display Size (Inch) - 18.5
    Screen Type - WideScreen LED
    Screen Resolution - 1366 x 768
    Brightness (cd/m2) - 250
    Contrast Ratio - 20000000:1
    Respons Time (ms) - 5
    Warranty (Year) - 3
    kamon mone hoy aita? feel free to give your opinion..
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    hmm Asus dekhte hobe..
    ekta jinish besh moja IDB onek dokane ee dekhi Monitor valo but aul faul low video chalaye rakhe..thats why monitor tar ashol capability dekha jaye na
    • Arif69's Gadgets
      • Logitech B100
      • ITS 500 Watt
      • KS
    SadIkMahdI,
    Philips 191EL2SB amar kase khub valo lage kintu amar mote tumi jodi [email protected] vai jei montiorta (Asus MS228H 21.5" 1080p) use kortese oita kinte paro tahole khub valo hobe.Karon oi monitortay ekta valo LED monitore ja ja thak dorkar ta sob kisu ase.Plus oitar screen 21.5 howay tumi kintu movie dekhew aro moja paba.Tobe er jonno tomar budget barate hobe plus gpu aro valo nite hobe :S. Tobe monitorta nite parle joss hobe !!!
    Montiortar customer review add korlam - Click here
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    18.5 LED amar jana mote philips r samsung tai ase asus ekta ase 21.5.. r tumi jei contrast ta dekhe khushi hoiteso oita actually dynamic contrast which actually doesnt matter in real life situations ..that just a business strategy of the manufacturers and oi DCr ta samsung er ta te 50000000:1...you should look for the actual contrast ratio samsung one is 1000:1 donno abt the philips
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by Arif69 View Post
    SadIkMahdI,
    hmm 21.5" nite parbo na.. taka nai.. plus GPU kannakati korbe..
    khub ekta valo jinish clear korla..ami vabtesilam j Ato beshi contrast ratio kamne hoy! r ase BeoQ, but BenQ kan jani ek2 o valo lage na..
    • Arif69's Gadgets
      • Logitech B100
      • ITS 500 Watt
      • KS
    Dorkar porle wait kore budget baranor chesta koro plus tumi kintu 4670 dieyw oi motiore mid settingse game khelte parba.Oitay HDMI,Dvi port,Ful HD support,2ms Response time sob kisuy kintu ase (Newegge 5 star pasie - Click here).Niba jokonh tokho best tai naw!!!Ar konovabei somvob nahole dekho onno konta choose kora jai .
  1. 20" LCD buying suggestion
    Last Post: June 21st, 2010, 03:46
  2. Help me buying a good LCD/LED monitor(budget 18k)
    By showdown_king in forum Others PC Hardware
    Last Post: June 12th, 2010, 17:10
  3. LCD monitor buying suggestion
    By outragedhuman in forum Others PC Hardware
    Last Post: May 27th, 2010, 08:53
  4. Confused about buying lcd monitor
    By LORÐ in forum Others PC Hardware
    Last Post: March 1st, 2009, 22:08
  5. Buying a 22'/24' inch lcd monitor...
    By hasib981 in forum Technical Support
    Last Post: October 28th, 2008, 19:46
Page generated in 0.34518 seconds with 15 queries.
