Results 1 to 20 of 24
Thread: XFX ATI 5670 problem
    Default XFX ATI 5670 problem
    My current set up ( very crappy and stupid):blushing:
    Pentium Dual core 3.0.
    512 x2 = 1GB RAM
    Asus P5GC-MX motherboard, LGA 775 (intel 945GC+ ICH7):blush:,
    Windows XP SP2 32 bit,
    250GB winstar digital HDD.
    Asus 17inch LCD. (currently set at 65hz for safety)
    Crappy *piece o sh*t* 400w "Space" psu (thats what the brand says)
    recently i have purchased an XFX 5670 from UCC.
    I installed it today in my mother board PCI exp 16x slot. Connected the monitor, everything ran fine and smooth,
    but just when I went to install the 'driver' that i got with the GPU box, the pc restarted itself. Every time i tried to install it, it restarted.
    So i took suggestions from friend and he told me to download a new driver/soft , and I did and installed that driver.
    This time PC did not restart or anything, everything went fine.
    Then i installed an old game (splinter cell 1 ) and in the middle of the game, everything paused and this error showed. (pic below)
    Page scrolling also started to become a bit 'lagged' and 'drowsy'. lol
    Uploaded with ImageShack.us
    My instincts tell me i may need a new PSU.
    But i need to be absolutely sure what could be the problem?
    The driver that i downloaded from net is this >
    • Rumen's Gadgets
      • Gigabyte GA-EP45-UD3RL
      • Intel Core 2 Quad Q9400 2.93 ghz(OC)
      • 3 GB 1333 mhz DDR3
      • Samsung 320 gb HDD
      • Xfx 5850 1 gb DDR5 BLACK edition
      • Samsung 2243 1920x1080 HD LCD monitor
      • built in Realtek
      • Cosonic CD-721MV
      • xbox 360 controller
      • Coolermaster 600 watt ati xfire certified(italy)
      • ASUS 16x DVD Rom
      • 2 and 16 GB Pendrive
      • Name onek boro, lekhte parbona
      • Windows 7 nd xp
      • 7.1 in Windows 7 index(sometimes 7.2)
      • 2009-2013 porjonto valo vabe game khelte parlei hoy.
      • SMILE
      • 30-35 kBps normal and 200kBps-7MBps from local torrents.
      • 30-40 kBps normal and 150-500 kBps from local torrents
      • 9
    Rumen's Avatar
    Azimpur
    Default Re: XFX ATI 5670 problem
    Shuvo vai, windows 7 setup die dekhte paren. Coz win 7 auto driver setup kore, oita try kore dekhte paren.
    Anywhere Anytime Anytask
    Nothing but Excellence
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    Quote Originally Posted by Rumen View Post
    Its better use the ati driver instead of the windows driver!
    & he has 1GB of ram so its better to stick with xp unless another 1GB is added.
    So u can install a fresh xp again and try with some old driver like 10.8.
    I bleed red, Man Utd 4ever..
    You need to change ur psu now or then,ur ram may be crappy,format hdd & install a fresh copy of os
    • Rakin's Gadgets
      • Gigabyte GA-X58-USB3
      • Intel Core i7 920 Cooled by TT Frio (dual fan)
      • Transcend 2 GB + Silicon Power 2GB DDR3 1333Mhz
      • 1 TB Hitachi @ 7200 RPM 32MB Buffer
      • XFX AMD Radeon 5850 Black Edition
      • ASUS MS228H 21.5 Full HD 1080p
      • 10-channel (7.1) Dolby Home Theater Audio subsystem using the Realtek ALC892 audio codec
      • Creative Inspire M4500 4:1 , A4 Tech Headphone
      • A4 tech KBS - 8
      • A4 tech 2X office 7K
      • Xbox 360 Controller for Windows
      • ASUS 650 Watts
      • BenQ 24X
      • Transcend StoreJet 320 GB , Transcend 4 GB Pendrive
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • The Killer Machine
      • Qubee WiMAX @ 256 kbps
      • 32 KBps
      • 7-8 KBps
    try usin windows 7...........
    • wolf's Gadgets
      • Asus p5g41c-m lx
      • Core 2 Duo E7500 2.93GHz
      • 2x2GB DDR3 Twinmos
      • Samsung 500 GB
      • Gigabyte Radeon HD 6850 1GB GDDR5
      • Samsung SyncMaster 2033sw
      • Delta 500w
      • Transcend 500GB StoreJet 25M
      • Windows 7
    wolf's Avatar
    It could be a hardware problem
    a) I heard one of the reasons which causes VPU RECOVER to act is when the card becomes too hot. Download RivaTuner and click on the hardware monitoring and let it record the temp in the background while you play the game for a while. See if the highest recorded temp is too high
    b) It could also be the game, some pirated games are poorly cracked and cause problems. Try playing a different game and see if it happens again.
    c) It may be a driver problem, go to http://xfxforce.com/en-us/Help/Support.aspx and register your product to download the driver from there. They slightly customize the catalyst drivers for their graphics cards.
    thanks for the replies, the current driver i have also has the heat monitoring system i think.
    here it is.
    But the question, is why is it getting over heated? is it because lack of power ? wattage?, isnt this 5670 capable of running without heat problem?. It is supposed to be efficient than 4XXX cards right?.
    The temp shown in that picture never gets over 60'C.
    PS: By the way, the driver I am using is the latest one as suggested in this thread.
    http://banglagamer.com/forums/showth...-10.11-out-now
    10.11 something.
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Not 10.11 something, its actually 10.11 (WHQL version), so driver version is not a problem here. And from the screenshot I can see the card is clocked down (idle mode). Run a stress test application like Furmark and see how hot it gets. I don't think its heat problem, but give it a try. Make sure your PSU is OK. Unbranded PSUs suck ___. You may try another PSU or dual PSU setup or test the card on a friend's PC. Suppose it did not solve the issue. Then...
    # Download and install driver sweeper.
    # Express uninstall all ATI software.
    # Uninstall the video card driver from device manager and if it wants a reboot, do so but remember to boot in safe mode. If you do not, you will have to repeat this step again.
    # Run driver sweeper in safe mode and choose "ATI - Display" and click on clean. It will ask for a reboot, do so.
    Your problem should be solved. Driver sweeper will clean the registry as well as leftover files and prepare your system for a clean driver installation. If all of these do not solve the problem, clean install your OS (I recommend Windows 7).
    ati heat monitoring can't show you the heat during load......download hwmonitor and keep it running during games.......what's the amperage of +12v rail of your crappy psu??? I can't understand why the current value of gpu/memory clock r too low....get a delta 400W @ 3k.... reinstall driver & keep ati overdrive untouched....test ur ram using memtest86.......u should upgrade it upto 3gb...
    • Rakin's Gadgets
      • A4 tech KBS - 8
      • ASUS 650 Watts
      • BenQ 24X
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • 32 KBps
      • 7-8 KBps
    Quote Originally Posted by eXpert View Post
    All ati 5000 series idle gpu/mem clock are 157/300 at load they increase....this is called ati powerplay.......at idle it switches to 2D clocks nd at load it'll switch to 3D clocks...nd ur temps are ok imo.....but get a branded psu...............
    Quote Originally Posted by Rakin View Post
    No.... definitely wrong......my younger brother's gigabyte hd5670 idle gpu/memory clock always remains 400/1000(defult setting).....i dont know about xfx or.......... and @ shuvo89 u should not enable manual fan control ......it will decrease fan's lifetime & not safe with such cheap psu.
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    ^rakin is right.if u oc or down clock ur amd 5xxxcard it increase its 2d clock(both mem,gpu).it is normal coz it is coded in d bios.u can fix this by moding bios.
    Shuvo89 1.first upgrade ur psu.it is endangering ur pc's life.
    2.then try
    event.msi.com/vga/afterburner/download.htm
    for load-time clock,fanspeed,temp monitoring
    3.then try some other 3d stress programs,games
    4.try older drivers.10.8,10.4
    5.format ur os. nd try xpsp3 or win7(better)
    • Rakin's Gadgets
      • A4 tech KBS - 8
      • ASUS 650 Watts
      • BenQ 24X
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • 32 KBps
      • 7-8 KBps
    ur brothers card remains up because he overclocked it using catalyst see his clotcks is 10mhz more than default......but all non-oc'ed , factory oc' ed cards uses powerplay..........nd powerplay er jonno heat kom hoy......nd in 10.11 driver oc korleo powerplay kaj kore....
    No... he never oc'ed that .............gigabyte 5670 is factory oc'ed
    • Rakin's Gadgets
      • A4 tech KBS - 8
      • ASUS 650 Watts
      • BenQ 24X
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • 32 KBps
      • 7-8 KBps
    yes he did....he moved the side 10mhz up....factory oc'ed cards have powerplay.......even if i oc my card powerplay wont work wid drivers below 10.11 but wid 10.11 powerplay works no matter wat......nd mines factory oc'ed but powerplay works......can u tell the model number of his card?????.....
    ---------- Post added at 16:42 ---------- Previous post was at 16:37 ----------
    ati overdrive diye oc korse btw.........
    ---------- Post added at 16:50 ---------- Previous post was at 16:42 ----------
    Ati users who r expericned i need ur help to make this noob understand........ Hemlock bro aishe ektu Expert re bujchao....
    Here u can find details about gigabyte gv-567OC-1GI
    • Rakin's Gadgets
      • A4 tech KBS - 8
      • ASUS 650 Watts
      • BenQ 24X
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • 32 KBps
      • 7-8 KBps
    if thats his card then the card is faulty cause 2d clocks r 157/300 for all 5000 series cards.....
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    Graphics card don't use the full core speed when not necessary just like the CPU EIST technology.
    My Sapphire HD4770 runs normally @250Mhz but when i play games it increases to 750Mhz.
    I don't overclock it
    • Rakin's Gadgets
      • A4 tech KBS - 8
      • ASUS 650 Watts
      • BenQ 24X
      • Powerpac 1200 VA
      • Windows 7 x64
      • 1000/1000
      • 32 KBps
      • 7-8 KBps
    I knw....but mr. expert noob eigula bujhe na!!!
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Mr. Expert er display name ta joss... Perfect match!
  1. Sale (Used) XFX ATI Radeon HD 4870 xxx Edition
    By shoshe in forum Shop - Gadgets
    Last Post: November 30th, 2010, 12:26
  2. Replies: 13
    Last Post: July 15th, 2010, 04:51
  3. ATi 5670 review
    By shaikh_imtiaj in forum GPU
    Last Post: January 20th, 2010, 02:05
  4. Replies: 5
    Last Post: December 3rd, 2009, 16:38
  5. Problem in XFX hd4650 ddr2 1024MB
    By Cyber_Shot in forum GPU
    Last Post: March 23rd, 2009, 20:48
Page generated in 0.31364 seconds with 14 queries.
