Thread: Can't use HFS, using Dhakacom, please help.
    Feb 2015
    Unhappy Can't use HFS, using Dhakacom, please help.
    I'm using Dhakacom for 2 weeks, I tried sharing files via HFS but I can't, what might be the reason and how can I solve it?
    They don't use a NAT, so it should work fine.
    Try turning off your local firewall, if you have one. If you use a router, it's probably the one blocking the port -- you'll have to figure out how your router works, and how you can open a port on it.
    Check to see if SPI Firewall in router is on or off, if its enabled then disable it, and you are done
    Feb 2015
    Thanks guys, I figured it out eventually. Aasifz ur idea worked, cheers mate.
  1. DhakaCom Discussion
    By nurtel9 in forum ISP
    Last Post: November 12th, 2015, 16:52
  2. Dhakacom users
    By blitzkrieg in forum ISP
    Last Post: June 30th, 2013, 21:10
Page generated in 0.15784 seconds with 14 queries.
