Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
Thread: UPS and Surge Protector Buying Help!
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    Question UPS and Surge Protector Buying Help!
    The season of thunderstorms and burning PCs is here again and I need to buy an UPS and a Surge Protector.
    Budget is around 5k for the UPS and around 2k for the surge protector. What and from where should I get it?
    Quote Originally Posted by MusharratC View Post
    PowerTree 1250VA for 4.8k (Superior Electronics Ltd). And this of Belkin http://www.ryanscomputers.com/Belkin-SUPER-641 for 2.8k. You will get 3 years warranty and 50k moneyback insurance with it.
    I have similar queary as OP.
    Is the power tree one the PowerTree S1250P from here? Does it really support monitoring from PC through USB/RS232 and some software like Rups 2000?
    Yes. And yes.
    Yes. And yes.
    Ok, then my search is over. Now I have to find some way to buy it from chittagong.
    I regret buying Spark Power 1200VA -_-
    Shall buy the ups soon. Stupid apollo crap.
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570 3.2GHz
      • G.SKILL Ripjaws (2 x 4GB) DDR3 1600 Bus
      • Samsung 840 Evo 120 + Samsung HD103SJ 1TB
      • Sapphire Dual-X R9270X 2GB
      • Benq V2220HP
      • Realtek HD Built-In
      • Creative 2:1
      • Ortek Multimedia MCK-800
      • Logitech HD Optical Mouse
      • Corsair CX600
      • Lite-On DVD-RW / Asus-DVDROM
      • Power Tree 1250P Offline UPS
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    How much does a USB/RS232 cost? The lowest I found was 520 taka. The name is Z-TEK 1.8M USB to RS232 Cable.
    It is the same product on the picture, but comes on a slightly different packaging.
    Are there any other cheaper option?
    Quote Originally Posted by Rubab View Post
    You have a com port in your motherboard. You have also got a RS232 cable for free with your UPS. Plug that into your com port. Done!
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Benq V2220HP
      • Creative 2:1
      • Corsair CX600
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    I got a white 9-Pin M/F UPS Serial Cable with my UPS:
    This is what the Back Panel of the B85M-D3H motherboard looks like:
    The Male connector goes to the UPS and the female one goes to I don't know where.
    BTW, I tested using the "PowerManagerLite" and found out that the auto-shutdown function works great but even though I tick the "Turn OFF Ups" option, it doesn't turn the UPS Off.
ID:	35768Click image for larger version.
    Com port is in the internal header. That's the problem of newer gigabyte motherboard
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Benq V2220HP
      • Creative 2:1
      • Corsair CX600
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    Yeah, that is a problem. I looked at the manual and failed to find a COM port in the internal header too. Bepar na.
    Is there a solution to the UPS not turning OFF after the PC shuts down?
    The screenshots from my previous post show the Parameter settings of the UPS. Is there anything on there which if changed will also Turn the UPS off?
    What does the UPS Polarity settings do?
    the port that you are showing is a VGA port not a COM port. u will be needing a header to port thingy to make it work, the header is on the mainboard itself.
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    What about the 3.2k Belkin power strip? Is there any difference between the 2.8k strip and the 3.2k strip other than just two additional ports? :/
    Quote Originally Posted by GalibTheGamer View Post
    Nope. No difference apart from the two additional ports
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
    MusharratC's Avatar
    Feb 2013
    does ryans provide the 50k insurance? or do I have to go to speed tech,was it? also, what documents do i need? I don't have a national ID yet so any replacement for that?
    one more question, does the monitoring software come bundled with it or is it a third-party software?
    and VANGUARD bhai ftw!
    You have to go to speed tech.
    Only National ID card or your father's national ID card who has a TIN number.
    The monitoring software comes bundled with it.
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
    MusharratC's Avatar
    Feb 2013
    TIN number too? OK. thanks a lot bhai!
    There is, the 2.8K strip will provide you a protection against 46,500 Amps of surge while the 3.2K one will protect you against 86,000 Amps of surge.
    If the surge is higher then the rated protection level, you will not be able to claim warranty nor any damage funding from the vendor you have purchased.
    [/B]
    And for the person showing to know everything but not knowing anything, unless and until someone doesn't know the facts, he should not provide misinformation .
    According to the weather forecast station in BD, usually the type of thunderstorm we have in all out of our country creates 56000 Amps of current spike on average, so if you go for the 2.8K one, good luck with that buy!
    Try to save some more and get the Ultimate 3.2K one, lot of my clients are happy with that particular model and you will be well protected and insured too, whilst the insurance is of 1,00,000 BDT!
      • Logitech K270
      • EVGA G2 850W
    May 2013
    Quote Originally Posted by FATAL1TY View Post
    Thanks a lot for the info bro
  1. Did your PS Vita came with a screen protector?
    By muscle in forum PSP/PS Vita
    Last Post: May 13th, 2013, 04:24
  2. Replies: 0
    Last Post: August 8th, 2012, 02:28
  3. what is the function of a surge protector.
    By Metal in forum Others PC Hardware
    Last Post: February 4th, 2012, 19:56
  4. Google Revenue Surge Sets Record
    By Riese in forum News
    Last Post: October 18th, 2011, 22:21
  5. Surge Protector
    By outragedhuman in forum Others PC Hardware
    Last Post: March 15th, 2009, 22:24
Page generated in 0.32325 seconds with 15 queries.
