Thread: Need suggestion for buying psu and ups
    • rumy's Gadgets
      • Asus p8b75m-V
      • intel i5 3470
      • Transcend 8 GB ddr3 1600mhz
      • Hitachi 2 TB
      • Gigabyte GTX 660 OC ddr5 2GB
      • Dell E1912H 18.5 inch
      • Microlab m 108
      • Gigabyte M5050
      • Logitech f310
      • Cooler Master GX 550 , 80+ Bronze
      • ASUS DRW-24B5ST
      • Transcend 32 GB
      • Power Guard 650 VA
      • Windows 7 Ulitimate 64 bit
      • Processor 7.5, Ram 7.8, Graphics 7.9, Gaming Graphics 7.9, Harddisk 5.9 ( according to WEI, win7 )
      • Zip Cyber Cafe (Bengal Group Limited)
    rumy's Avatar
    Sep 2012
    Default Need suggestion for buying psu and ups
    Hello,
    My 2 year old PSU cooler master GX 550W is not working properly. After I removed my graphics card it can boot up my pc but I am getting frequent auto restarts (see attachment).
    Can I fix my psu in any shop or I need to buy a new one ? If I need to buy a new one which one I should buy for my i5 3470 and gtx 660 setup. I need suggestion for a UPS within 3-3.5k to shut down my pc properly. Thanks in advance.
    @sensei can you help :/
    first of all if u suspect that it's your PSU, then don't turn on the pc again. first check the psu mostly the voltages and if possible ripple too( if u have access to any oscilloscope you can measure that)
    later you can open up the PSU and check for visible errors, maybe bulged capacitors or some blown stuffs.
    if you wanna buy a new one, buy a toughpower 550W or something, for the UPS avoid Apollo done.
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Those can be serviced right?
    • rumy's Gadgets
      • Asus p8b75m-V
      • intel i5 3470
      • Hitachi 2 TB
      • Microlab m 108
      • Gigabyte M5050
      • Logitech f310
      • ASUS DRW-24B5ST
      • Transcend 32 GB
    rumy's Avatar
    Sep 2012
    Do you know if Toughpower 550w is currently available in bd and its price ? If I cant find it in IDB tomorrow any alternate that I can choose ?
    Quote Originally Posted by Trave160 View Post
    if the problem is just the capacitor or one or two small parts being blown, those can be serviced.
    Quote Originally Posted by rumy View Post
    check UCC.
  1. GPU an PSU Buying Suggestion !
    By matrixon in forum GPU
    Last Post: July 2nd, 2014, 15:15
  2. Need suggestion on buying led tv
    By DarkMan in forum Help - General Shopping
    Last Post: November 27th, 2012, 23:47
  3. GPU suggestion w/o buying PSU
    By rafatjami in forum Help - PC Buying
    Last Post: December 3rd, 2011, 23:24
  4. PC Buying Suggestion
    By Raa in forum Help - PC Buying
    Last Post: October 5th, 2011, 06:18
  5. Need Suggestion for PC Buying
    By DarkMan in forum Help - PC Buying
    Last Post: June 12th, 2011, 08:53
Page generated in 0.17390 seconds with 15 queries.
