Results 1 to 10 of 10
Thread: Power Supply Help - CX750
    Default Power Supply Help - CX750
    So I was working with my project today and needed 5V and a very high amount of current ( About 5A) so I thought of using my CX750, while working I have noticed something very disturbing. The Standby power of this power supply is about 2.4V-3.1V, It should be 5V right?
    so I have tasted my cheap old value top power supply and found out that value top was providing 5V on its standby rail.
    So my question is, is my CX750 down? I understand one possibility is it's standby transformer and the circuitry might be down somewhat, not the transformer but the circuit that provide the standby power.
    By the way once its powered up all of its rail provide proper voltages.
    So, my questions,
    1. Is it down?
    2. Can I claim for warranty?
    3. Do you think it's safe to use? (judging the facts that USB always on ports get power from standby 5V but lower voltage might not burn it still...)
    and a request,
    1. anyone have a corsair CX-750, can you do the same test and post result?
ID:	35718Click image for larger version.
    any kind of input will be appreciated.
    no one?
    no one?
    i'm afraid you can't claim warranty for this. To me it seems to be this way by design.
    i just noticed that you are measuring the green 5v vsb Standby green cable. The main use this 5vsb line is to retain memory during S3 state. So it's not designed for the high power draw.
    and if u keep stressing that poor fella you might loose S3 standby capability of the PSU and in worst case you won't be able to power on your PSU.
    Green is the standby pin, if the psu turns on it goes to zero. as long as the psu is off it should provide 5V no matter what, all the other psus i have tasted do this, each one of them can provide 5V. And this psu should have done that too.
    i was measuring the voltage with a voltmeter, how the hell that could be a high power draw?
    again im not stressing the psu.
    anyway so i can't claim warranty for this :S
    damn should have waited for TT Tough to be restocked stupid corsair.
    anyway after turned on it works nicely though
    http://redwanhasan.blogspot.com/2015/02/temporary.html
    I thought U r trying to run a high power application off the 5vsb while the psu is in standby.
    Can you try putting ur system in S3 state see if it works?
    If that 5vsb reads only 2.43 you probably won't be able to put ur pc in S3 state
    and in that case u may try going for a RMA. But it would be hard to convince them i guess.
    nope i was just measuring and then found out this.
    i know it will be hard for me to convince because this psu can run the system with full SLI load flawlessly,
    thats what i think too.
    will try later and will try to convince them see what happens.
    and if u can measure ur psus voltage... if possible please share
    USB always on port usually gets power from the 5V Standby and CX750 should provide 15W on this standby rail but it wont work unless it can provide 5V.
    some more pictures
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    are u sure about that ? did u measure the current of 5vsb rail under load ?
    Quote Originally Posted by @nonymous™ View Post
    when the power supply is off, the only rail that provides power is the Standby rail, so where else do u think the power comes from?
    and no but check the label of CX750 it says it can provide 3A on standby pin http://redwanhasan.blogspot.com/2013...r-general.html
    another thing it doesn't mean that when power supply is on it is burning the whole 15W. There should be circuitry for sensing it and lowering the power.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    i thought that u meant it for both ON & OFF state as u mentioned the word 'always'. once someone in jonnyguru forum claimed something like this
    my mistake i meant the "usb always on" function of my board. i think it might be a design flaw or could be the standby circuit damaged somehow sadly it still has warranty. otherwise i would just open it up.
  1. Power supply
    By yahyasharif in forum Others PC Hardware
    Last Post: June 22nd, 2014, 16:50
  2. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  3. power supply
    By Spider72man in forum Help - PC Buying
    Last Post: September 30th, 2011, 00:43
  4. Replies: 21
Page generated in 0.22305 seconds with 15 queries.
