Results 1 to 11 of 11
Thread: motherboard problem maybe
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    Default motherboard problem maybe
    recently my pc is acting weird. windows time changes automatically even when i am using the pc. tried to change the time in he bios but bios was unresponsive, it hanged like the picture below, restarted few times, totally powered of but nothing happened, then turned off pc unplugged the sata cable from hdd just for a minute replugged it, now the bios is accessible. changed the time in the bios to 8.53 tured the pc but time is showing 8.49 then re entered into bios and the bios time is showing 8.50. what is the problem here? even for this time changing problem cant save fifa 15 properly.
Name:	2015-02-12 20.44.38.jpg
    Get a new bios battery, CR2032
    Duracell ones are great, Newsun and Hitachi ones are also available.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    sorry for late reply. how much those battery cost. and still i have warranty. so i may ask for a battery from the shop i bought mb.
    Quote Originally Posted by Arka karlos View Post
    won't cost you more than 50TK, and these are easily found in local electronic or watch shops.
    original hitachi/maxell might cost more than that, like 120 or something.
    hmm but eigula boro shop chara pawa jai na
    local store gulate newsun e sob cheye beshi thake, 30-60tk te sell hoi.
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    ok, ar bios freezing problem tao ki battery er karone hoi naki onno kono problem ase? ar ai battery gula dokane ki name poricito cmos battery? @redwan hasan @Aasifz
    ok, ar bios freezing problem tao ki battery er karone hoi naki onno kono problem ase? ar ai battery gula dokane ki name poricito cmos battery? @Aasifz
    battery er jonno o hoi abar onek somoi update korte giye bios e problem holeo hoi, age battery paltaye dekhen, thik hoye jabe most hopefully, hmm cmos battery bollei chine. battery er model number dekhe niyen obosshoi, it's cr2032.
    can u flash the bios?
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    are you asking me? no i cant. bios update is generally not needed right?
    yes, it is not needed if everything is fine clearly its not the case, you can try changing the bios then.
  1. Want to Buy WTB P55/H55 motherboard
    By Dee in forum Shop - Gadgets
    Last Post: October 18th, 2013, 21:48
  2. Want to Buy Any h61/h67/p67/h77 motherboard
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: June 8th, 2013, 08:53
  3. Nvidia Driver Problem or Graphics Card Problem ??
  4. Motherboard Problem
    By Perfect_Galaxy in forum Motherboard
    Last Post: October 27th, 2011, 09:22
  5. Sale (Used) Motherboard & RAM
    By abir in forum Shop - Gadgets
    Last Post: November 23rd, 2010, 03:44
Page generated in 0.22618 seconds with 15 queries.
