Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 20 of 108
Thread: Need Help / Advice.
    • fishd990's Gadgets
      • Intel DH55HC
      • 2 GB DDR3
      • Samsung HD322HJ (320 GB) & Transcend Storejet (TM)25 Mobile (160 GB External)
      • Sapphire HD 5770 1 GB DDR 5
      • Samsung Syncmaster 2243BWX (22")
      • ATI High Defination Audio Bus
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • XBox 360 Controller for PC (Chinese)
      • Thermaltake TR2- 500 W
      • Bluetooth, Printer (HP Laserjet 1010), Scanner (HP Scanjet 4370)
      • 800 VA (Gives upto 15 Min to my PC)
      • Windows 7 Ultimate
      • BTCL Broadband 256 Kbps
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    Default Need Help / Advice.
    I connected my PC with a HDTV(I have ATI 5770). When I start the PC, I get the booting screen on my TV. But when the blue welcome screen is suppose to appear, I get no picture on TV. I checked with all other Display ports on my card. All of them display my desktop but not the HDMI port.
    Now here’s where the problem gets really weird. I connected the HDMI cable with my laptop and I get the laptop desktop on my TV. Then I reconnected with my PC the problem is gone! I got my PC desktop on my TV again. I restarted and there were no problems.
    This was yesterday. But today the same thing happened again. First, I won’t get my desktop. I connect it with the laptop, then reconnect, I get my PC desktop on TV.
    Any one has any idea why this is happening.
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: Need Help / Advice.
    Quote Originally Posted by fishd990 View Post
    it is d strangest prob., i have ever seen.try 2 detect display set manualy .and d res. native (as hdtv-19 by 10)...try 10.8 catalyst or 10.9 coz i had much similar prob. with monitor in DVI in10.10
    ---------- Post added at 10:02 ---------- Previous post was at 10:00 ----------
    But ,d solution was n't by reconnecting by laptop..but by making pc sleep and wake up again..
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    wat is ur desktop default resolution wid monitor?
    Also install latest catalyst.
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    I have the latest catalyst. I use 720p as desktop resolution(but tried all available resolution). I have tired manual detection, all available resolution, even tried forcing, no luck.
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    try 10.8 catalyst express installation..then try d possible resolutions again.
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    I tried 10.11, but I had no luck, so I formatted my PC.
    Its OK now but my PC is running on a basic Graphics Driver. So should I update the driver to the latest version or can anyone suggest me a version that will not show this problem. The current driver only supports 800X600, so its not an option.
      • Logitech G500s
    Tom@L's Avatar
    San Francisco, USA
    taile either hdmi port e problem ba cable faulty. Airokom to howar kotha na. Shuni nai karor. Amar chena onekei ase aibhabhe HDTV te movie dekhtese from computer at 1080p.
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    try 10.8 drivers.i told u before.
    ---------- Post added at 19:03 ---------- Previous post was at 19:02 ----------
    I m sure it will work. Well, at least hope.
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    10.8 doesn't work, same problem. Any other ideas?
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    So I Have tried almost everything to solve this, no luck. I just wanted to ask if anyone will lend me some cables. I just want to try before I go buy anymore cables. I need a HDMI to HDMI and two other types of cable, If anyone can lend me these please PM/Post
    Here are the other two
    HDMI to DisplayPort (DP)
    HDMI to Component
    • Rakin the Devil's Gadgets
      • Gigabyte X58-USB3
      • Hitachi 1TB 7200 Rpm
      • A4tech Gaming Keyboard
      • A4tech X7 747H Gaming Mouse
      • BenQ 24x DVD-RW
      • Powerpac 1200VA x2
      • Windows 7 SP1 x64
      • Check Links in Sig..
      • 140+
      • 50+
    Jan 2011
    I have only HDMI to HDMI cable nd HDMI to DVI cable.
    ---------- Post added at 22:38 ---------- Previous post was at 22:35 ----------
    y do u need the other 2?
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Quote Originally Posted by Rakin the Devil View Post
    Check the dates
    Bumping into old threads misguides everyone into posting in those old threads
      • Gigabyte X58-USB3
      • BenQ 24x DVD-RW
      • Windows 7 SP1 x64
      • 140+
      • 50+
    Jan 2011
    Quote Originally Posted by error View Post
    Check the dates
    I got a link to this thread frm the opener....nd do u have to say that always?
    • error's Gadgets
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Oh, nevermind then -__- And yes i said this coz of that 5670 thread which was a year old, and tomar recent post dekhe amio recent thread mone kore post korsi -__-
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    HDMI to HDMI is of no use to me. HD 5770 has a DisplayPort I just wanted to see if that solves my problems. Catalyst 11 was also released will try that too. The TV has component input so I wanted to try that too. These are my last hope.
    Try installing the driver with the TV connected. A friend of mine faced an issue with the resolution not reverting back after he switched back to his monitor from his TV, he reinstalled the driver and everything's working fine.
    ---------- Post added at 01:44 ---------- Previous post was at 01:43 ----------
    A full clean install by the way.
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    Do you mean that re installing the whole OS or just uninstalling and then re installing CCC
    No not OS lol. Completely deleting the old driver, use Driver Sweeper, it'll do everything for you. But carefully select the ATI drivers only.
    Yah, Driver Sweeper is the best.
      • Intel DH55HC
      • 2 GB DDR3
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    Different Topic: What can I do with old P4 and Celeron PCs. The P4 one does not run. Is there I can sell them, price is not an issue I just want to get rid of them.
  1. Need advice on buying PC
    By Necray in forum Technical Support
    Last Post: January 28th, 2011, 15:22
  2. Need advice!
    By Marfi in forum Motherboard
    Last Post: August 2nd, 2010, 20:03
  3. need advice for buying new pc
    By LORÐ in forum Technical Support
    Last Post: January 1st, 2010, 12:21
  4. Need some advice for pc
    By tofu in forum Technical Support
    Last Post: May 27th, 2009, 18:27
  5. Need Advice
    By Uchiha Obito in forum Technical Support
    Last Post: April 12th, 2009, 02:13
Page generated in 0.31266 seconds with 15 queries.
