Results 1 to 20 of 29
Thread: Host Problem in GameRanger
    Default Host Problem in GameRanger
    sorry 2 open a new thread 4 this, but i cant find a solution to the hosting problem in gameranger,no one seems to be able to join when i host.dedicated server was off and punkbuster disabled...pro's would you plz help??
    • master_tanjid's Gadgets
      • HP-Intel HM65
      • Intel Core i5 - 2410m @ 2.30GHz
      • 4.00 GB Single-Channel DDR3
      • 640GB Western Digital WDC
      • AMD Radeon HD 6750m 1gb ddr5
      • Generic PnP Monitor ([email protected])
      • Altec Lansing
      • HP dvd rom
      • windows 7 premium 64bit
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Jalan Gombak, Kuala Lumpur, Malaysia
    Default Re: Host Problem in GameRanger
    download this fiile.. http://www.fileserve.com/file/UP8Nm7a u will need to replace this file "iw3mp.exe" with the main iw3mp.exe file... this should do it
    thanx man...i'll try this...btw host korle amar game slow chole, keu join na korleo...any solution for that??
    • The_game's Gadgets
      • Intel DX58 SO
      • Intel Core i7 920
      • Transcend 4GB 1333 Bus
      • Samsung 500GB
      • Nvidia GTX 260
      • 22" Samsung Syn 2233 LCD Monitor
      • Built In 7.1 Realtek Sound Card
      • Creativee 5.1 Speaker
      • A4 Tech
      • A4 Tech
      • Logitech Cordless RumblePad 2
      • Thermaltake Tough Power 650W 650W
      • HP dvd1060 DVD RW
    The_game's Avatar
    Dec 2009
    Shantinagar
    Make 'Anti-Alliasing' -Off in settings
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    yeah tht shud do it as the game said
    1)What message ur friends get when they try to join ur server?
    2)Is ur cod4 patch updated to 1.7?if not then update...
    3)set ur cod4 keygen to UJTD-U2YQ-242E-2MYW-D351
    4)Is ur cod4 installation Disk was double DVD ITnext or NP&P?Skullptura RIP is not good.
    Quote Originally Posted by The_game View Post
    i did... but there's no change. the game runs perfectly when i join a server...dont know what the problem is
    ---------- Post added at 15:38 ---------- Previous post was at 15:35 ----------
    Quote Originally Posted by Taher fuious™ View Post
    1-actually i'm not sure...maybe cd key problem
    2-it is updated to 1.7
    3-i will try this 1
    4-it was double dvd IT next
    i face no problems when i join any game but while hosting people cant join and more importantly, my game runs slow.
      • GIGABYTE GA-G33M
      • DDR2 4GB 800MHz Bus
      • Semsung HDD320GB SATA
      • ASUS GeForce EN9600GT (1GB)
      • Samsung 17" LCD Monitor
      • Realtek HD Audio 5.1
      • Sony Surround HD Deck 15" & Microlab TMN-8 2:1
      • A4 Tech
      • A4 Tech
      • XBOX 360
      • ATX 12V/1200W Modular
      • Twinmos 4GB
      • Compro 1200VA
      • Windows 7 : Ultimate and Windows XP
      • 1 mbps
      • 0.70 mbps
     $hr 's Avatar
    Jan 2010
    Bangladesh
    Quote Originally Posted by gunner93 View Post
    You are using windows 7 which is not properly compatible with game ranger so that cod4 cant be hosted. You have to install windows vista or xp for opening cod4 host in game ranger.
    Quote Originally Posted by $hrƒƒ View Post
    i guess u r ryt.....
    I have the same problem..... And you guys are saying that I'll have to throw my PC back to the stone age to HOST on GR even when I have a Smile(Diamond Package) with the main server right next to my home... So sad. There has to be some other solutions to this problem..
    Download This FILE ::
    Call of Duty 4 v1.7 PRIVATE WINDOWS SERVER PATCH #1
    from gamecopyworld.com.....i have win7 and after replacing the main iwMP.exe with this i can host in GR with no probs
    Quote Originally Posted by zfr View Post
    I tried this, but now ppl see "waiting for host" and their game doesnt start...
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    lower graphics.. then anti aliasing off koren.. this shud work
    Quote Originally Posted by master_tanjid View Post
    buchhi ebar...ami host korle amr game ta ektu slow chole...low grafix eo(laptop er jonno maybe).....eijonno hoy na, but onno karo server e pura smooth chole...so host kora posible na ei pc te....but thanks a lot for the help
    ami to sob kota korechi but tao same probs hochhe .. ami host hochhi kintu kau join korchena ,,
    1.7 update patch mara ache .. crack o deoa ache .. but hochehna ..
    plz help me
    • W1C|<3D's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo
      • 3GB
      • Samsung
      • Gigabyte 9500 1 GB[factory overclocked]
      • HP 1859m
      • A4TECH GK-85
      • Logitech MX 518
      • 500 watt
      • ASUS Sata DVD RW
      • Windows Se7en Ultimate X64
      • RAM 5.5,HDD 5.8,Processor 6.4,Gaming Graphics 6.2
      • Meh....
      • BTCL ADSL
      • 64+
      • 30+
    W1C|<3D's Avatar
    Narnia :O
    There is a patch is Gamescopyworld.com named Call of Duty 4 v1.7 PRIVATE WINDOWS SERVER & NO-WAIT PATCH #1. It solved my host problem in windows 7
    No 7. No discussion, sharing or referencing game hacks.
    BG Rule Book
    Quote Originally Posted by W1C|<3D View Post
    I had a issue with gameranger automatically creating a COD server meaning hosting wouldn't work. The patch fixed it.
    Thanks!
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5&quot; Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    i use Windows 7, And I can host easily on win 7...
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Quote Originally Posted by Hamilton View Post
    ei kothata nov 24th 2010 e bolte parlana?
      • 16GB DDR3 1600hz
      • Roccat Arvo
      • 500GB
      • Windows 7/ Linux
      • Smile, BD.COM
      • 75KBPS(Variable)
    Hamilton's Avatar
    ei post ta nov 24th 2010 e dekhi nai...
  1. browsing problem - generic host process..
    By Noob in forum Software
    Last Post: December 7th, 2010, 19:53
  2. CoD 4 Cod 4 host Problem!
    By $hr in forum Call of Duty
    Last Post: August 17th, 2010, 23:54
  3. FIFA Tourney GameRanger Tournament
    By Valkyrie in forum Tournaments
    Last Post: July 18th, 2010, 19:50
  4. FIFA 10 gameranger problem
    By -\/IpeR- in forum Older FIFA Games
    Last Post: May 15th, 2010, 00:51
  5. Generic Host Problem
    Last Post: October 30th, 2008, 02:14
Page generated in 0.31235 seconds with 14 queries.
