Thread: NVIDIA GeForce 3D Vision 2 Wireless Glasses Kit 3D glasses - active shutter
    • Speed's Gadgets
      • Creative ZxR| Built In
      • ASUS DVD +/-RW
      • USPOWER 2000va Online UPS
      • Windows 10 Pro 64 bit
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Default NVIDIA GeForce 3D Vision 2 Wireless Glasses Kit 3D glasses - active shutter
    Item Description :
    Discover the difference NVIDIA 3D Vision 2 can make in your PC gaming experience. The new gamer-inspired 3D glasses have 20% larger lenses to give you the most viewing area with the least light leakage. They also work great with the innovative NVIDIA 3D LightBoost™ technology, which makes your screen up to 2x brighter for better 3D gaming and video viewing. Plus, 3D Vision 2 glasses are built from state of the art, softer materials designed to deliver more comfort and better fit.
    Key Features:
    NVIDIA 3D LightBoost technology combines patented 3D monitor technology and improved 3D glasses design to deliver increased monitor brightness by up to 2x and reduced 3D ghosting when 3D Vision is enabled. In addition, users get increased environment brightness allowing you to view your keyboard more easily.
    High tech active shutter glasses, designed with top‐of‐the‐line optics deliver Full HD 1080p resolution per eye, best in class ghost free images, and ultra‐wide viewing angles.
    3D Vision monitors are not just beneficial for 3D. They deliver best in class 2D gaming with performance twice the speed of standard LCDs. Unleash ultra-clear, smooth motion 2D gaming up to 120fps and superior image with reduced motion blur, latency, and frame tearing to bring life-like reality to games and video.
    Built for PC gamers with twenty percent larger 3D lenses for a wider viewing area and increased external light blocking for total 3D immersion.
    Bigger 3D
    - Try new 27'' 3D monitors from ASUS and Acer for Full HD 1080p 3D and ghost-free image quality
    - Experience games more fully with 20% larger lenses for an ultra wide viewing area
    - Get the most diverse ecosystem of content-including 3D photo sharing and browsing-on 3DVisionLive.com
    Brighter 3D
    - Get up to 2x monitor and keyboard brightness with NVIDIA 3D LightBoost technology (Requires NVIDIA 3D LightBoost equipped monitor)
    - Experience the new external light blocker that minimizes the effects of overhead lighting
    Better Gaming
    - Play over 600 PC games in 3D including the latest titles like Batman: Arkham City, Crysis 2, and L.A. Noire
    - Enjoy softer composite materials and better fit with gaming headsets
    - Get best-in-class 2D gaming with ultra-smooth 120 fps gaming on 120Hz monitors
    Glasses
    Infrared receiver : Receive signal between 1.5 and 15 feet
    Battery Life: 60 hours
    Power button: On button
    Rechargeable battery connector: USB 2.0 mini-B power connector
    Battery Level: Green and red indicator lights
    Charging : Flashing amber light when charging, solid amber when fully charged
    Product Dimensions: 6.5" x 6.4" x 1.6"
    Product Weight: 56 grams/1.96 ounces
    Fits comfortably over prescription glasses if you wear them.
    IR Emitter:
    Infrared transmitter: Transmit signal between 1.5 and 15 feet
    NVIDIA backlit button: 3D Vision on/off
    Depth Adjustment: Thumbwheel on the back of IR emitter
    USB 2.0 mini-B: Connect to the PC for enabling 3D Vision
    VESA Stereo Cable Port: For use with DLP HDTVs and Quadro GPUs only
    Product Dimensions: Length 164mm x Width 163mm x Height 41mm
    Product Weight: 47 grams/1.66 ounces
    Package Contents:
    3D Vision Glasses
    3D Vision USB IR emitter
    1.8m USB cable
    3m USB cable
    VESA 3-pin cable
    Storage pouch
    2 nose pieces
    User Guide
    Condition: Almost new
    Used Duration: hardly some hours
    Reason for selling: 3d is definitely not for me
    NOTE: in order to use this product u must have a 3d vision ready monitor or tv which is capable of at least 120hz of refresh rate. if ur monitor/tv doesn't have the specified capability pls don't waste ur money on this product.
    Market price: 9920 .tk source: https://www.google.com/shopping/prod...ed=0CFsQ8wIwAA
    BD market price: 22,000 .tksource: http://www.clickbd.com/bangladesh/57...asses-kit.html
    My selling price : 8500 (non negotiable )
    No off topic pls. i do not want valuable suggestion from anyone.
       1
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    update:
    price is now NEGOTIABLE
       0
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    *bump
       0
    • Speed's Gadgets
      • ASUS DVD +/-RW
      • DHAKANET
      • 750
      • 650
    Speed's Avatar
    Khilgaon
    Sold!
       0
  1. How to Make 3D Glasses?
    By Nirzhar Uchiha in forum Technical Support
    Last Post: July 12th, 2012, 23:34
  2. Where can I get Anti Glare glasses?
    By Robin Rayhan in forum Miscellaneous Topics
    Last Post: April 27th, 2012, 10:43
  3. 3D Glasses
    By йЦммєя³¹ in forum Help - General Shopping
    Last Post: February 5th, 2011, 14:34
  4. 3d monitor+glasses
    By showdown_king in forum Others PC Hardware
    Last Post: March 16th, 2010, 22:11
Page generated in 0.18086 seconds with 15 queries.
