Results 1 to 14 of 14
Thread: BTCL ADSL Connection Problem
    Gazipur
    Default BTCL ADSL Connection Problem
    Hi
    I'm new user in Gazipur, BoardBazar. I connected my phone line to Spliter then modem. I successfully connected to internet. but the problem is sometime ADSL LED light became dead (also my internet) after some time it going to online again. some time this is ADSL Led light does not on. So please anyone can solve this problem? My Modem TP-Link TD-W8950ND. Thanks
    • SinEater's Gadgets
      • ASUS P5K-VM
      • Pentium E 2200
      • 6 GB DDR2, 800 MHz
      • Samsung 500 GB + 500 GB
      • 450 GTX
      • Samsung 933SN LCD
      • Realtek, integrated
      • T6200 5.1
      • Razer Lycosa, Razer Arctosa
      • Razer Lachesis, Razer Death Adder L/H
      • Microsoft SideWinder
      • Corsair 650 W
      • Asus Combo Drive
      • Qubee 1mbps
      • 20
    SinEater's Avatar
    Mogbazar, Dhaka
    Default Re: BTCL ADSL Connection Problem
    There are several things that can be the issue. Your modem might be faulty. The telephone line you are using, I mean the actual cable may have physical damage, or the connections at the end might be poor. Or, your splitter might be the cause. I suggest posting your snr and attenuation here so other users may advise you properly. To be sure about the hardware, try to get a set for one day from someone.
    Click here to find out how a noob plays the Anti Mage
    Honesty and Modesty were the best policy...they still are.
    A single stupid man can ask more questions than a thousand wise men can answer
    <nfs>.......for life..
    Gazipur
    Quote Originally Posted by SinEater View Post
    How i measure my modem's SNR?
      • ASUS P5K-VM
      • Pentium E 2200
      • 450 GTX
      • Samsung 933SN LCD
      • T6200 5.1
      • Corsair 650 W
      • Asus Combo Drive
      • Qubee 1mbps
      • 20
    SinEater's Avatar
    Mogbazar, Dhaka
    You can log into the modem using any browser. The default ip should be 192.168.1.1. The user name and password should be printed in the modem itself or the manual, probably admin and admin. From there, you should be able to get the snr.
    • blitzkrieg's Gadgets
      • Intel DG41RQ
      • Intel Core 2 Duo E7500 Wolfdale (45nm)
      • 4GB DDR-2 800 MHz Dual Channel
      • 250 GB Samsung
      • Sapphire Radeon HD5870 PCIE 2GB GDDR5 256BIT
      • LG Flatron W1942SR
      • X-Fi platinum
      • Creative Gigaworks 5.1
      • Standard
      • Standard
      • Thermaltake Tough Power 650 watt
      • Samsung DVD writter
      • Rahimafroz 550 va
      • Windows 7 Ultimate x64
      • I'm satisfied.
      • 20
      • 56
    blitzkrieg's Avatar
    First disconnect your modem. Attach a phone set and see that whether you can hear a dial-tone. If you can, replug the cable and login to your modem with a browser window. The address would be something like 192.168.1.1 or 192.168.3.1. See the Signal to Noise Ratio (SNR) and post it here.
    • DarkMan's Gadgets
      • Asrock P67 Extreme6
      • Intel Core i7 2600k @ 4.7ghz [WaterCooled]
      • 2 x 4GB G.SKILL Sniper @ 2133mhz 11-11-11-30
      • Samsung EVO 840 250GB SSD, Segate 2TB + Hitachi 750GB + Samsung 1TB + 250GB + 160GB HDDs
      • Gigabyte HD 5870 1GB @ 900/1250mhz
      • AOC I2251Fwe
      • Creative X-Fi Titanium HD
      • Microlab FC-360 2.1 / Sennheiser HD 558 Headphone
      • A4tech multimedia keybord
      • Logitech G500, Deathadder 2013
      • Xbox 360 Controller
      • Corsair TX-650watt
      • Transend 4 GB Flash Drive; ATI TV Wonder 600
      • Apollo 1200va
      • Windows 8 Pro 64-bit
      • Acording to WEI : 7.8, 7.9, 7.8, 7.8, 7.9
      • Housed in a tt Spedo Advance Case
      • Btcl 1mbps
      • 115 KBPS
      • 32 KBPS
    DarkMan's Avatar
    you can also try to change ADSL Mode. it may help to get stable connection. i was using G.dmt mode then i switched to G.lite and the SNR margin jumped to 17.5/9 from 7/6.
    Also check Attenuation [its in same place where SNR is]. if its too high then you i'm afraid you can't do anything as it indicates the distance between telephone exchange and your modem.
    EDIT : If the splinter is lying on floor, put it on a higher place. i'm not sure that it'll definitely work. just give it a try.
    "Down here in the atmosphere
    Garbage and city lights
    Gonna save you’re tired soul
    Who's gonna save our lives ?"
    Gazipur
    Here is detail,
    Plz advice
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS P8Z77 V Delux
      • Intel Core i7 3770K @3.9GHz
      • EVGA 980Ti 6GB
      • Samsung 17&quot;+22&quot;+22&quot;
      • Realtek HD Audio &lt;internal&gt;
      • Creative Inspire 5:1
      • Razer BlackWidow Ultimate
      • G7
      • Seasonic X 850W 80Plus Gold
      • External DVD-RW
      • Link3/Amber IT
      • 10000
      • 10000
    CvP's Avatar
    Low download SNR
    High download Super Frame Error.
    Poor phone line quality (excessive noise/electromagnetic interference)
    Gazipur
    Low download SNR
    How could i remove this errors?
      • Intel DG41RQ
      • 250 GB Samsung
      • X-Fi platinum
      • Standard
      • Standard
      • Rahimafroz 550 va
      • I'm satisfied.
      • 20
      • 56
    blitzkrieg's Avatar
    Quote Originally Posted by austin View Post
    The problem lies within BTCL's exchange end. Which exchange are you under?
      • ASUS P5K-VM
      • Pentium E 2200
      • 450 GTX
      • Samsung 933SN LCD
      • T6200 5.1
      • Corsair 650 W
      • Asus Combo Drive
      • Qubee 1mbps
      • 20
    SinEater's Avatar
    Mogbazar, Dhaka
    It can also be a problem of the cable that is being used to connect to your phone.
    Gazipur
    Quote Originally Posted by blitzkrieg View Post
    I'm Using Boardbazar, Gazipur's Exchange.
    ---------- Post added November 15th, 2010 at 08:03 ---------- Previous post was November 14th, 2010 at 21:03 ----------
    Anyone can tell, what is the standard SNR Margin (dB) & Attenuation (dB)?
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://beta.speedtest.net/result/6780327218.png)
      • 10m+20m
      • 10m+20m
    coldfire7's Avatar
    ADSL Router Line Stats - http://bit.ly/aSs2sn
    Default How do I improve adsl 512k infinity internet speed?
    Hello Brothers!
    Can anyone help me how do I improve my BTCL ADSL internet line.Although my package is 512k infinilty.
    I share my status which is
    Modulation
    G.DMT
    Annex Mode
    ANNEX_A
    Downstream Upstream
    SNR Margin
    6.0 7.0 db
    Line Attenuation
    50.5 31.0 db
    one more things my telephone line from db box 200 meters far away and 4 joint as usual.
    so please give me good solution for me to get better internet speed
    Thanks again all of you
    s u Z o n BOss
  1. BTCL ADSL Connection
    By Deep -xCross- in forum BTCL
    Last Post: February 26th, 2016, 09:24
  2. how to connect to btcl adsl
    By lavluda in forum BTCL
    Last Post: September 9th, 2011, 02:50
  3. BTCL ADSL Connection of Chittagong
    By gogeta in forum BTCL
    Last Post: December 17th, 2010, 15:11
  4. Any BTCL ADSL user,please ping these IPs
    By xN :: ABiR in forum BTCL
    Last Post: November 27th, 2010, 19:20
  5. BTCL ADSL Connection
    By gogeta in forum Internet
    Last Post: July 24th, 2010, 23:41
Page generated in 0.27013 seconds with 15 queries.
