Results 1 to 20 of 31
Thread: Connection timed out problem solved :D
    Default Connection timed out problem solved :D
    ami btcl er user...ami last ek mash dhore fifa 11 khelte partesilam na ei problem er jonno...problem ta actually lan card er jonno....notun ekta lan card install korlei problem solved ....lan card er daam 400\500 er moton....ENJOY!!!
    Default Re: Connection timed out problem solved :D
    Which lan card did u buy and are sure about this ??
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    i was facing connection timed out problem today [played after many days]
    then i set the ip address dhcp instead of setting static ip address.
    then it works! i was able to play again!
    btw, i use smile (bdcom)..
    I bleed red, Man Utd 4ever..
    • $/\IF's Gadgets
      • Asus P5QPAL-AM
      • Dual Core 2.60 Ghz
      • 3 Gb
      • 320
      • Nvidia 9500 GT
      • Bilt In
      • A4 Tech
      • A4 Tech
      • Windows 7
      • 25
      • 25
    Lightbulb Re: Connection timed out problem solved :D
    amio To BTCL user,bt asholei ki solve hoise,Ami Eto Din Bilt In E Chalatam.. Plz Reply
    Hi i found some patch that in most of the cases remediates the problem. enter this link http://www.fotbal-live.eu/concurs/frag.php?player=Vlad and press the button to download.Good luck!
    Cool Connection timed out
    Hi...i've just shifted to smile(bronze package) today only to play fifa11 in gameranger!but for some strange reason...it says "connection timed out" when it should join the lobby(in game)!i have another problem...that is..when fifa11 starts and they shows the "official licensed product"...it gets stucked there for a bit..like 2 or 3 minutes...did i actually miss something??something like BDIX server e khelar jonno ki extra kichu kora lage?naki just normally gameranger diye khellei hoy?im sorry im a noob in online gaming never tried it before!any solution will srsly help me guys i'm going crazy to play fifa in gameranger :<
    • patron_saint's Gadgets
      • Gigabyte P55-USB3
      • Intel Core i5 [email protected] with Xigmatek Dark Knight
      • G.Skill Ripjaws [email protected] 9-9-9-24
      • 1 TB Seagate Barracuda 7200.12, 120 GB Seagate Barracuda @ 7200rpm
      • ECS GTX 560
      • ASUS MS228H 22&quot; LED 1080p
      • Realtek 7.1
      • A4tech Glasser
      • Razer Onza TE | Logitech Chillstream | xbox 360 controller for windows[wired]
      • ASUS 50GA 500w, +12V2.2, Active PFC
      • ASUS DVD RW LightScribe
      • Win 7 Ultimate SP1 x64
      • Smile (Silver)
      • 64 KBps
      • 32 KBps
    patron_saint's Avatar
    left center back
    Quote Originally Posted by silent View Post
    Hi...i've just shifted to smile(bronze package) today only to play fifa11 in gameranger!but for some strange reason...it says "connection timed out" when it should join the lobby(in game)!i have another problem...that is..when fifa11 starts and they shows the "official licensed product"...it gets stucked there for a bit..like 2 or 3 minutes..any solution will srsly help me guys i'm going crazy to play fifa in gameranger :<
    go through these threads please - http://banglagamer.com/forums/showthread.php?11230-How-to-play-Multiplayer-in-Game-Ranger-FIFA-11-PC
    http://banglagamer.com/forums/showthread.php?11740-Connection-timed-out-problem-solved-D
    Check your firewall settings, make sure the firewall isn't blocking your connection.
    Use the latest patch/updates. Refer to this thread - http://banglagamer.com/forums/showth...1-Crack!-Squad
    ps - try tunngle aswell. its better than GR.
    take a look at this thread - http://banglagamer.com/forums/showth...E-Post-your-ID
    Quote Originally Posted by abir View Post
    @abir bhaiya how do i set the ip address dhcp instead of setting static ip address?details please?im having the same problem!ajkei smile nilam only to play fifa!
    • abir's Gadgets
      • DELL Inspiron 18.5&quot; LCD |14.1&quot; TFT LCD
      • ASUS 16X DVD Drive &amp; Liteon DVDW| Asus DVD RAMRW LightScribe
      • OVO 650VA
      • Windows 7 x64 | Windows XP SP2 &amp; Ubuntu 9.04
    abir's Avatar
    Azimpur
    @silent
    ok check this image
    @silent
    ok check this image
    @abir bhaiya should i use the same ip that u used?or i can find that ip somewhere in my pc?
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    @silent
    yah u can use it or anything else
    Should be like this: 192.168.0.xyz (xyz = 1-254)
    @silent
    @abir bhaiya thanks a zillion for this!!
    • RGX's Gadgets
      • Biostar
      • Intel Pentium Dual Core 2.4 Ghz
      • 2 GB
      • Ati radeon 4650
      • Windows Xp
      • Banglalion 512 kbps
      • Around 60+
    Jul 2011
    Bhaiya... I have recently installed the patch 1.01 in fifa 11..!!! Before when i did not have any patch i never had any problem playing but now after installing the patch the game is not running very smooth...Reponse is not happening in time and its lagging. I use a Banglalion Wimax 512 kbps connection....!!!! Please help about what to do in order to get smooth flowing game play....!!!!! Thanks a Lot Bro...
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20&quot; LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    ya same problem with me after I reinstalled windows.. before that fifa was awesome but now the menu is very laggy any solution??
    @abir
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    Quote Originally Posted by RGX View Post
    Quote Originally Posted by abhi4168 View Post
    @abir
    Did you turn on Vsync/ATI micro stuttering?
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    nop didn't turned those on
    • master_tanjid's Gadgets
      • HP-Intel HM65
      • Intel Core i5 - 2410m @ 2.30GHz
      • 4.00 GB Single-Channel DDR3
      • 640GB Western Digital WDC
      • AMD Radeon HD 6750m 1gb ddr5
      • Generic PnP Monitor ([email protected])
      • Altec Lansing
      • HP dvd rom
      • windows 7 premium 64bit
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Jalan Gombak, Kuala Lumpur, Malaysia
    @abir
    GR e khelle lag hoi? naki emnite offline khelleo lag hoi?
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Quote Originally Posted by master_tanjid View Post
    gr e hoy amonki kakar oi jinish ta ashei na...menu te background balck thake.
    • RGX's Gadgets
      • Biostar
      • 2 GB
      • Ati radeon 4650
      • Windows Xp
      • Around 60+
    Jul 2011
    Only ATI micro stuttering is on Vsync is off!!! The lag is actually happening during the match by just about 1 sec..!!! Khub shamanno deri kortese protita move ey... pass ey.. shot korar shomoy..!! Khub ei irritating ekta jinish bhaiya..! is there any solution to it???
    • abir's Gadgets
      • OVO 650VA
    abir's Avatar
    Azimpur
    That's a FIFA problem regarding GR.
    I faced this problem also.
    After gr starts the game it became black with laggish menu.
    Then I had to wait in game to let the lag go.
    If you alt+tab few times the black screen will go and menu will be shown, but you have to wait in lobby.
    But start the game without GR, black screen problem should not arise. I saw this problem only playing in GR.
    And it came randomly and solved randomly for me.
    ---------- Post added at 23:43 ---------- Previous post was at 23:42 ----------
    turn off micro stuttering..
    lag in online/multiplayer matches? That's kinda obvious if your net is not good!
  1. FIFA 11 Tips Connection Timeout Solved for Tunggle/Gameranger
    By Hamilton in forum FIFA 11
    Last Post: May 18th, 2011, 15:06
  2. Replies: 7
    Last Post: November 15th, 2010, 12:36
  3. PS3 Internet Connection Problem
    By shon_91 in forum PlayStation
    Last Post: September 20th, 2010, 14:02
  4. Want a Better connection @ shantinagar
    By Banglavai in forum Internet
    Last Post: March 17th, 2010, 13:00
  5. Which is the best connection for gaming
    By raptordhk in forum Internet
    Last Post: August 3rd, 2009, 00:18
Page generated in 0.31335 seconds with 14 queries.
