Thread: sandisk cruzer blade 32gb write protected problem
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    Default sandisk cruzer blade 32gb write protected problem
    this sandisk 32gb cruzer blade says write protected can not be formatted even the filled up bar doesn't appear, after trying to remove the write protection via Command promt "location is not available" shows up. can any body know a way to solve this problem
    @redwan hasan @VANGUARD @Swapnil
    Attached Images Attached Images
    I think the drive is kaput. But still, try all the methods mentioned here: http://www.makeuseof.com/tag/how-to-...n-a-usb-stick/
    Name:  0511-1002-2300-5961_Black_and_White_Cartoon_Grave_with_RIP_on_the_Headstone_clipart_image.jpg
    • Ghost Riley's Gadgets
      • ASRock Z370 Extreme 4 [Case: Thermaltake Commander GS-II black]
      • Intel core i5 8400 @ 3.9Ghz
      • Corsair Vengeance LPX 16GB @3600Mhz (Dual Channel)
      • Toshiba 2TB
      • Sapphire RX480 Nitro+ 4GB
      • Dell S2216H IPS panel (1920X1080)
      • Creative X Fi Titanium
      • Edifier R2000DB
      • A4 TECH KR-85
      • Havit-MS736
      • Antec Neo ECO 650M [80 PLUS BRONZE Certified]
      • Samsung SH-S223
      • Transcend 32GB USB 3, Adata C906 32GB USB 3, Adata UV120 32GB USB 3
      • https://valid.x86.fr/bench/5bqlvf/1
      • ochcham
      • Alpha Broadway
      • 130-150 KBps
      • 100-150 KBps
    Ghost Riley's Avatar
    Narayangonj
    Epic!!!
    its dead most probably, but still try HP pendrive format tool, see if anything happens
  1. Sale (New) SANDISK CRUZER GLIDE 64GB USB2.0/3.0 compatible
    By REVx in forum Shop - Gadgets
    Last Post: May 22nd, 2014, 03:39
  2. Replies: 1
    Last Post: March 4th, 2014, 18:39
  3. Usb drive write protection problem
    By Banglavai in forum Technical Support
    Last Post: August 16th, 2011, 21:10
Page generated in 0.17218 seconds with 15 queries.
