Results 1 to 20 of 21
Thread: Sound Card for audio.
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Core i3 530 @ 2.93Ghz
      • 2gb DDR3 Twinmos 1333 and Transcend 4gb 1333
      • Samsung HD502HJ
      • Sapphire HD7750 1gb DDR5
      • LG Flatron W1953TE 768p
      • A4 Tech KR-83
    Nov 2012
    Nowhere, Oklahoma, United States
    Default Sound Card for audio.
    So I burnt my audio chip and now my pc does not have any sound output. The softwares say its fine but nothing on hardware. I was thinking if I can add a sound card to get my audio back. At present I don't have the money to replace whole mobo. My specs:
    Processor: Core i3 530 @ 2.93GHz
    Motherboard: Intel DH55HC
    GPU: Sapphire HD7750 1gb ddr5 (Gonna get a r7 265)
    PSU: Thermaltake 750W Smart
    Ram: 2gb ddr3 Twinmos and 4gb ddr3 Transcend (Total 6gb)
    On a side note Anyone know if I can get a PCI 1.0 to PCI 2.0 converter?
    Quote Originally Posted by IMNOPRO View Post
    you sure the codec is activated in the bios?
    If the codec was disabled in bios the software or device manager wouldn't show it. I've seen this case before on my friend's PC, the chip or something on the audio circuitry is really damaged (if obviously OP is not missing some tiny mute button on some hidden place of his driver settings). In case of my friend he RMA'd his mobo, same thing happened again, and after 7 dead motherboards, 1 dead GPU, 2 dead RAMs he had to replace his power supply.
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Quote Originally Posted by swapnil View Post
    7 dead motherboards, 1 dead gpu, 2 dead rams
    O.O
    O.O
    Yap. All within 2 years, all covered by warranty. So no worries. I just don't get it why did the shop take so long to find the actual problem.
    didnt notice that "software say its fine" portion. anyway i was just checking
    things happen!
    and yes something can go wrong thats for sure!
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    Yes I posted this problem on another thread for a fix. Someone (maybe you) posted something similar about the PSU. So I should get a sound card. As far as I know though the audio chip fried after my attempts at overclocking this CPU. Also the room I was in previously was warmer so CPU temps stayed around 90+'C
    (yes thats a quotation mark) so that could be the reason. Again SO I SHOULD GET A SOUND CARD OR WHAT?
    Which PSU do you have? And how old is the motherboard and the PSU?
    Yes you should get a soundcard if you cannot replace the motherboard. But I'll suggest replacing the motherboard would be a better idea. But before that make absolutely sure that you have tested everything software related. Check your bios, or maybe even reset your bios. Check every section of the audio driver settings. Maybe if you have time try with a fresh windows reinstall. Also check audio jacks, see if your audio driver supports jack retasking, and set some other jack as audio output. Finally check if changing from front panel to back panel (or vice versa, whatever applies to your case). After all, it would be stupid to replace working hardware for a software fault, right?
    U can get some usb sound card of some sort, should get the job done fot now, and check ur psu and mobo to avoid future catastrophe
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    Done and done. Already did all the troubleshooting here. I use a Thermaltake Smart 750W 80 Plus Bronze power supply that I brought with me from the US. The mobo is Intel DH55HC Media series Standard ATX mobo.
    Then just get a sound card. If you get something decent you'll get much better audio quality than a replaced motherboard's onboard audio.
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    I found a few decent ones on ryans. Thermal take would be best right?
    Thermaltake makes soundcards too??!! I didn't know. I personally like Asus and Creative. If you don't absolutely need USB take a look at this. It's a really good card at for this price.
    what if this one fires too!
    If it happens within 1 year then no problem. He'll just claim warranty for soundcard and replace the PSU.
    Usb should be a bit more safe
    Not sure about that. The power is still coming from the motherboard, as for the PCI-E card. On the other hand, I'm sceptical about the quality of thermaltake audio. I have more trust in asus. Asus have USB DACs too, but they would be more costly.
    Usually usb ports come with fuses and current limiter so thr should be less chance of getting fried but that card should yield more performance than tts audio.
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    I don't think PSU is the problem. My GPU is fine. I've had it for two years now. No problems whatsoever. Even after I OC the thing. I fried the audio probably because it was reaching near 120 temps. All I did to OC the cpu was change the multiplier to around 50 I think. It was 30 on default. Anyone know where I might get a PCI 1.0 to 2.0 converter?
    That's highly unlikely.
    Why do u need the converter?
  1. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    By areek in forum Shop - Gadgets
    Last Post: August 23rd, 2013, 23:34
  2. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    Last Post: December 30th, 2012, 17:27
  3. Sale (New) Creative Sound Blaster X-Fi Xtreme Audio
    By OoAIDoO in forum Shop - Gadgets
    Last Post: July 27th, 2011, 08:50
  4. Sale (New) Sound Card: M-AUDIO PRO TOOLS M.POWERED 7 Firewire Solo
    By sadi_warhead in forum Shop - Gadgets
    Last Post: June 26th, 2011, 03:00
  5. Sale (Used) Creative Sound Blaster AUDIGY Value 7:1 Sound Card
    By Reventon in forum Shop - Gadgets
    Last Post: February 10th, 2011, 17:22
Page generated in 0.37624 seconds with 14 queries.
