Thread: Connection Timeout Solved for Tunggle/Gameranger
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    Default Connection Timeout Solved for Tunggle/Gameranger
    Those of you who are encountering problems when joining a room via GameRanger or Tunggle in FIFA 11 which is basically Connection Time Out, you can fix this problem by uninstalling your Lan card driver and reinstalling it again.
    To do this, Right Click on your my computer, go to Device Manager, select your LAN driver, my one included in the pic is the built in lan card.
    After Uninstall is complete, go to the Device Manager again, Right click on Network Adapters and Select Scan For Hardware Changes and Windows 7 will automatically install it.
    This process is for Windows 7 users only, Windows XP users will have to uninstall your lan driver from Add/Remove Programs and restart ur PC(Win XP sucks )
    **NB: YOU HAVE TO make a BACKUP OF YOUR IP ADDRESS, SUBNET MASK, DNS, ALTERNATE DNS, MAC Address FIRST(Only those who have it)
    SMILE/Dial UP users may have to set SPEED AND DUPLEX to 10 MBPS FULL DUPLEX to work. If u get connected then don't change anything from Configure option.
    This process worked for Me and @Valkyrie™ . I hope it works out for you guys. Credits goes to him for finding the solution
    PS: I'm not 100% sure that it'll work for you, so be wise and don't blame me, lol.
       1
    • master_tanjid's Gadgets
      • HP-Intel HM65
      • Intel Core i5 - 2410m @ 2.30GHz
      • 4.00 GB Single-Channel DDR3
      • 640GB Western Digital WDC
      • AMD Radeon HD 6750m 1gb ddr5
      • Generic PnP Monitor ([email protected])
      • Altec Lansing
      • HP dvd rom
      • windows 7 premium 64bit
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Jalan Gombak, Kuala Lumpur, Malaysia
    Default Re: Connection Timeout Solved for Tunggle/Gameranger
    this doesnt work.. those who are under a nat router... this wouldnt work for themmm...
       0
    tried both and yet not helped me...
    i use BSNL broadband and my bandwidth is 256 kbps...
    my downloading speed is 60 kbps..
    i have played FIFA 09 and 10 using hamachi ... this is my first time with GAMERANGERS.. and I was able to play just once and everytime after that it shows CONNECTION HAS TIMED OUT..
    help me out here..
    thanks in advance
       0
    • tilakpranesh's Gadgets
      • ASUS
      • Intel Core 2 Duo E7500(Overclocked at 3GHz)
      • 2x2GB
      • 500GB
      • ATI Radeon HD 4650
      • Windows 7
    Chennai, India.
    You have to configure your modem to solve this problem of connection time out in gameranger. Like setting your modem to PPPoE mode, static IP, etc. But don't be alarmed, its quite easy and follow the instructions here.http://forumofthoughts.blogspot.com/...meouts-in.html
       0
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    Quote Originally Posted by tilakpranesh View Post
    most of us dont have modem... plus i am sure even if we buy a modem we wont be able to login as our ISP blocks ports and all and we are not even provided with real IP!
       0
      • ASUS
      • 2x2GB
      • 500GB
      • Windows 7
    Chennai, India.
    Quote Originally Posted by master_tanjid View Post
    I don't know how you can have internet connection without a modem and you can always login into your modem to configure it. But not sure about the ISP blocking all ports. You should switch to some better ISP.
       0
      • HP-Intel HM65
      • Altec Lansing
      • HP dvd rom
      • Maxis Broadband
      • 500
      • 200
    Sep 2008
    isp's dont keep the modem/routers in our house... they give several connections from one modem/router and they dont give username or pass to those modems.. and all isps over here are same
       0
  1. FIFA 11 GameRanger ID
    By LynAs in forum FIFA 11
    Last Post: March 6th, 2015, 17:02
  2. Replies: 19
    Last Post: April 24th, 2012, 16:38
  3. FIFA 11 Connection timed out problem solved :D
    By nino90 in forum FIFA 11
    Last Post: August 3rd, 2011, 05:06
  4. Moon Microbe Mystery Finally Solved
    By anik_lc in forum News
    Last Post: May 8th, 2011, 00:48
  5. FIFA 10 gameranger problem
    By -\/IpeR- in forum Older FIFA Games
    Last Post: May 15th, 2010, 00:51
Page generated in 0.20368 seconds with 14 queries.
