Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
Thread: Need help with buying a phone
    Default Need help with buying a phone
    So I need a phone, budget is not more then 20k BDT.
    now these criteria must fulfill
    1. Android ( no I don't wanna use windows)
    2. Dual Sim, Dual Standby ( Must be Mini Sim)
    3. Snapdragon preferred.
    4. Can live with low quality camera but need good display and audio circuit.
    5. Good battery.
    Redmi 1S is in my mind right now, but suggest me anything.
    Thanks in advanced aka TIA Pakhi
    anyone
    • Shawon191's Gadgets
      • Gigabyte H-61
      • Intel Core i5 3570s 3.1 GHz
      • 4 GB DDR3 1600
      • Samsung 850 Evo 256 GB + WD 1 TB
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • Thermaltake TRS 550W
      • Aamra Technologies
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    Go for Moto G 2014, great device with confirmed OS updates and better durability and audio quality that matches flagships.
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Intel Core i5 2310 (2.9 Ghz)--Stock Clock--Stock Fan
      • PQI-4gb-1333 Bus-single stick.
      • SAMSUNG Sata-2 (320gb)
      • Gigabyte 660-OC-2GB-Windforce2..
      • Samsung B1930-LCD-18.5 inch :(
      • Built in.
      • Creative Inspire T3200 (2:1)
      • Value Top-normal (multimedia)
      • A4tech X7..
      • Thermaltake Smart 550w- Modular
      • Samsung Writemaster-- Not using currently -_-
      • Apacer 8gb Pendrive-usb2-_-
      • Prolink-650VA
      • Windows 7-Ultimate-64bit
      • Gaming is fun, but Acquiring a Satisfactory setup for it is not -_-
      • 190kpbs
      • Havn't checked yet!
    -RAKIB-'s Avatar
    Jan 2013
    Wht's TIA Pakhi btw?
    Redmi 1s Looks gd, but u can take a look at HTC desire 620 dual sim, it's a little lower powerful (in cpu, snap 410 series)..
    But useful as better front cam and upgraded OS..
    Why so Serious!
    Quote Originally Posted by shawon0418 View Post
    Moto G 2014 is definitely a very good device except for the fact that It lacks Dual sim option and 1080p video recording option. Using two cellphones is really a painful thing.
    Quote Originally Posted by -RAKIB- View Post
    Thanks in advanced.
    uses micro sim, i really don't wanna cut my sims
    and performance difference should be marginal.
    UPDATE:
    anyone know how good is a Zenfone 5?
    Thanks in advanced.
    Why do you have to cut the sims? Just go to your customer care centers of your mobile operators and they will give you microsims to you for only 150/- per sim. Easy.
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    It got dual sim version and dual sim version costs same as single sim.
    my sims are pretty old, both of them are almost 7/8 years old, dont wanna damage the look :v sounds lame right?
    lets see tell me which one would u prefer?
    1. Redmi Mi 1S
    2. Zenfone 5
    3. Moto G 2014?
    If i'd use Android i might take the Moto G 2014. But alas, the OS is so unusable and laggy.
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    1. Redmi Mi 1S
    2. Zenfone 5
    3. Moto G 2014?
    I'd say G 2014 matches all your criteria rather well. And Lollipop upgrade is already rolling out for Moto G. However all 3 of those are great devices.
    im using Lulipup in my nexus, not that impressive i must say -_-
    i really love the customizability of miui or whatever it is, and really like the aggressive price placement, also it doesn't come with a headphone,which is a + for me cause i already have a Skull Candy headphone,
    about G 2014, im not much of a fan of round shapes(when it comes to mobile phone) but im pretty sure both moto and asus are reliable than the Redmi.
    As said above, Moto G fills your criteria though, but if you like cutting edge phones then I MUST say, you should go with Redmi 1s. Got a nice design.
      • Gigabyte H-61
      • 4 GB DDR3 1600
      • GTX 660
      • Asus VX229H
      • Microlab M223
      • SteelSeries Rival
      • Logitech F310
      • 5 mbps
      • 5 mbps
    Shawon191's Avatar
    May 2014
    It all comes down to personal preference then. If you think Redmi will be better for you, then go for it.
    The audio output of moto G is truly exceptional. http://www.gsmarena.com/motorola_mot...iew-1139p7.php
    I'm using moto G 1st gen myself and this review says audio output of 2nd gen is even better.
    Also check this https://www.youtube.com/watch?v=bnWUBtaOjx8
    asus zenfone is great the 2gb version costs 17k as far i know but zenfones dont have the custom rom availability like snapdragon processors have unless its a great phone , i used the 1gb version and its really great in price and performance and great device for playing games but you have to cut down the sims as it doesnt support mini sims only micro
    mostly i need good quality audio, cause i listen to music often. and i need a good browsing experience and good battery, i dont need gaming performance.
    actually i didnt even root my nexus, i need stable operating system, not much of a fan of custom rom.
    and playing games is not an option, i only play pc games.
    anyway how is the audio quality? do u listen to metal and dubstep?
    yeah and last time i used moto was a RAZR V3i, and i really loved that phone. hope they have the same build quality.
    zenfone didnt come with earbuds so cant say input music quality but loud speaker was great and clear as it was my friend's so couldn't able to test everything but this device supports otg after an update but after the update it shows some bugs as well i read somewhere may be in gsmarena dont know about the recent conditions, but in stock rom this device seems fast and touch was satisfying
    I have used a asus tablet too, it has impressive audio quality, if same thing is true with zenfone i might take it.
    I guess i have to go and check for myself, if they allow me.
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    Asus Zenfone 5 is round shaped too :/
    and been reading reviews on GSMarena, not a gd review there, idk why!
    Since u like the design of 1S and specs r gd enough, I'd say, get it..
    Why so Serious!
    moto is more roundy and looks like samsung and i hate samsung!
    first i have to make sure about reliability, it has to support rough usage.
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    I guess 1s might b a little better if u use earphones.. It has Xiaomi's MiSound enhancer, which comes into play when you use headphones... and here's a review of sound quality, idk about specs so judge urself
    Why so Serious!
    guess its from GSMarena, yeah checked that. THD is pretty good, even better than Moto G when headphone is attached. although moto has better dynamic range.
  1. Phone buying help
    By Reznov in forum Help - General Shopping
    Last Post: August 2nd, 2014, 05:05
  2. Phone buying help
    Last Post: July 14th, 2014, 02:23
  3. Need help buying a phone within 15-17k
    By Mahraf in forum Help - General Shopping
    Last Post: September 22nd, 2013, 03:56
  4. Want to Buy Suggestions on buying a phone
    By Aziz in forum Shop - Gadgets
    Last Post: August 29th, 2013, 11:55
  5. Urgent........Phone Buying Help !!!!!!!!!!!
    By QuadStorm in forum Help - General Shopping
    Last Post: June 1st, 2012, 00:19
Page generated in 0.33138 seconds with 15 queries.
