Results 1 to 17 of 17
Thread: High Dynamic Range Imaging (HDRI) - A guide for beginners
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Default High Dynamic Range Imaging (HDRI) - A guide for beginners
    About this tutorial: This tutorial is made especially for beginners. The terms have been simplified than they should be in some cases. So, experts, do not complain, they are intended to be "noob-friendly". If you are an advanced user, you can also read through. You might learn something new. Topics are so vast that they deserve to have a standalone tutorial for each of them. So, I recommend you search the internet for more information about the topics to get a clearer idea.
    Introduction
    What is HDRI: HDRI stands for High Dynamic Range Imagery. What is dynamic range? Within the context of photography, dynamic range is the range of light, from little to much, that can be measured and recorded, normally by a single exposure. In simple words, it's the ability to "catch" the light in the image. Suppose, you have a cup and a bucket. Your bucket will hold significantly more liquid than your cup. Now apply the concept to photography, normal images hold little data, HDR images hold significantly more. Your eyes are designed to detect very high and very low light, and your eyes will auto adapt to catch the most amount of detail. But cameras cannot do that. See this image below.
    As you can see, your camera holds only a "fraction" of the dynamic range. To catch the scene as it is, you will need more than that. That's when HDR images come in. I strongly recommend you read this wikipedia article when you get some free time as it will help you a lot to understand what actually is HDR.
    Basic Knowledge
    Exposure: It's hard to simplify the concept of "exposure", but let's just say it determines how much light your camera will capture. Cameras shoot at a default 0 EV. Go negative (-1/-2/-3/-4/-5 etc.) and the image will become darker as you are capturing less light. The opposite will happen when you go to positive values (+1/+2/+3/+4/+5 etc.).
    Histogram: A histogram graphs the brightness values of individual pixels absorbed by the camera sensor within a digital image. Basically, it displays where all of the brightness levels contained in the scene are found, from the darkest to the brightest. It is basically a graph showing the brightness distribution of an image with pure black on one end, pure white on the other and grey in the middle. You might've noticed this before, but don't know what it means or does. To simplify this concept, see the image below.
    If your histogram looks like the left one, your image have lost detail in shadows. If it looks like the right one, then it has lost detail in the highlights. But if it does not touch the left and right edges and stays in the middle (any shape), then the both the highlights and shadows of your image are preserved. Most of the cameras now have the option to show histograms in camera. So, you can take a look at that and adjust your exposure bias to catch the detail.
    Bit Depth: This topic is complicated by birth, so we will try to skip the technical factors. Just remember it... the higher the bit depth of an image, the more information about the scene it will hold and therefore, the better. 16-bit images are a lot better than 8-bit ones, and 32-bit HDR images are significantly better than both 16 and 8 bit images. So, try to shoot/work with the maximum bit depth as it will make further editing easier and more flexible.
    Tone Mapping: HDR images have very high contrast ratio and thus, cannot be rendered by normal televisions or monitors. You need special HDR monitor to see the file as it is, and they are insanely expensive. How bright is the sun? And how dark is a cave? Just imagine your monitor is rendering a daylight scene where it hurts to look at the bright sun or sky but the shadowed cave is dark and has slightly visible details. An ordinary monitor cannot do that, but an HDR monitor can. Also, printed images do not have the ability to show such high dynamic range. So, there is a technique that reduces the contrast of the HDR image to get the details out but still maintaining an acceptable dynamic range which the monitors or televisions are able to render. This process is called tone mapping. The tone mapped image is basically a low dynamic range image. So, it is a process of converting high dynamic range images to low dynamic range images.
    What you need
    # A camera (be it point and shoot or DSLR)
    # Adobe Photoshop
    # Photomatix
    # Basic knowledge (included above)
    # Photoshop basic skill (the higher the better)
    You may use either Photoshop or Photomatix or both (I recommend both). If you want to go with only one program, then go with Photoshop as it will make post processing much easier.
    The Process
    You need at least 2 differently exposed images of the same scene (that means at the same time and same point of view). Most of the photographers use 3 differently exposed images. They may be +1/0/-1 EV or +2/0/-2 EV or theoretically any (most photographers prefer +2/0/-2). But try to keep the spacing constant. For example, you may, but should not go with +1.26/0/+2.14 EV. For intense scenes that have both very light and very dark areas, you might need a greater EV spacing (like +3/+2/+1/0/-1/-2/-3) to catch the details precisely. DSLR cameras are perfect for these conditions. Point and shoot cameras do not have much flexibility and only allow to shoot 3 differently exposed images at once. These set of differently exposed images are called bracketed photos/exposures.
    How you shoot the bracketed exposures varies depending on your camera. So, it is up to you to find out. Take the help of the camera's user's guide.
    Now when you have the bracketed exposures ready, put them in a separate folder (for the sake of arrangement). Then follow one of the two ways below.
    Photoshop: I have used Adobe Photoshop CS5 x64 for this tutorial:
    Run Photoshop. Go to File > Automate > Merge to HDR Pro
    # In the box that appears, click on Browse.
    # Navigate to the folder, select all exposures and click on OK.
    # You might choose to automatically align the images, and click OK.
    # Photoshop will align the images and open the HDR preview in the following window. Check "remove ghosts" if the image has moving objects. Then click OK.
    # An HDR image will be created. Save it for future usage. I recommend saving it as Radiance (.HDR) format. Then starts the real part.. tone mapping. Go to Image > Mode > 16 bits/channel. You could've chosen 8 bit/channel, but that way you will have smaller file size at the expense of image data.
    # A new box will open letting you adjust the look of your photo. Use Local Adaptation for maximum flexibility. The options speak for themselves and thus, is up to you to experiment with and get the result you want. When you are satisfied with the results, click OK to get the processed image.
    # You are almost done. You may want to reduce the noise generated in the process or sharpen the photo, it is all up to you. In some cases, you may have to tone map the same HDR image using different settings and paste them in a new file as layers. Then mask out the unwanted parts and adjust the opacity of each layer to get a "hybrid" tone mapped image. It requires a bit advanced skill in Photoshop. So, if you did not understand this point, skip it. You will surely do when you become a bit more skilled.
    Save the image as whatever format you want.
    Photomatix: I have used Photomatix Pro 3.2 for this tutorial:
    # Run Photmatix. I recommend reading the tutorial included with the program. It will help you understand things easily. Then click Generate HDR image.
    # In the box that opens next, click on Browse.
    # Locate and select all of the images and click Open.
    # It should show the file names. Click on OK.
    # The settings are easy to understand, and does what they mean. More info available in the built-in tutorial. Choose them according to your image. You may always use the following settings for most of the images.
    # The HDR image will be generated. When the process is complete, click on Tone Mapping.
    # Make sure you have Details Enhancer tab active. The terms are a bit technical here, so take the help of the tutorial included. Toy with the settings to get the best result. Click on Process to start processing the image.
    # You are done.
    Save the image as whatever format you want. You can also take the image to Photoshop for post processing. You may also use the Photomatix plug-in for Photoshop for tone mapping instead of the standalone version.
    Example
    I have used 5 different exposures for this tutorial. They are -1/0/+1/+2/+3. I have used a normal point and shoot camera. If you have a DSLR, you are likely to get better results.
    Although the main objective of HDR images is to bring out the details to make the image look "realistic", some people love more aggressive tone mapping. Some love those overdone images, some hate them. It's your call. If you want it to be realistic, you can do that. But when you decide to exaggerate the image, it will become somewhat artistic. An example will clarify this. Here is the 0 EV photo to the left, realistically tone mapped in the middle and overdone to the right.
    Here are a few other examples that you might want to check out as well:
    Another example showing 0 EV photo to the left, realistically tone mapped in the middle and overdone to the right.
    Here is a late afternoon sky, -1 EV photo to the left, tone mapped one to the right.
    Beautiful sky after raining, 0 EV photo to the left, tone mapped one to the right.
    A sunny and somewhat cloudy noon. Notice recovered details on the white building and the cloud. +1 EV photo to the left, tone mapped one to the right.
    Here is a sunset scene. 0 EV photo to the left, tone mapped one to the right. See how much detail is recovered.
    Here comes the overdone images. 0 EV photo to the left, tone mapped one to the right.
    Another aggressively tone mapped and color graded example. 0 EV photo to the left, tone mapped one to the right.
    Like both the realistic and overdone ones? Then why not mix these two? 0 EV photo to the left, tone mapped one to the right.
    Thank you for reading. I hope you will be able to shoot photos in High Dynamic Range from now on. Whenever you get time, read more about the topics and practice with different scenes. HDR is the future of photography, and you should be prepared.
    One example of bracketed exposures is attached with this post for you to experiment with.
    You may want to post your comments here if you want.
    Bracket.zip
    Default Re: High Dynamic Range Imaging (HDRI) - A guide for beginners
    What a big post!
    + Rep.
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    I tried to shorten it as much as possible. But if I shorten it even more, a beginner will have unanswered questions.
    • Aunee's Gadgets
      • Asus P7H555
      • Intel Core i5 760 8mb cash 2.80GHz OCed to 4.0GHz
      • 4Gb + 4Gb DDR3 1333bus
      • Samsung 120gb ata + Samsung 500gb sata
      • Sapphire AMD 6670 GDDR5 1GB
      • 19inch Samsung SyncMaster 943 LCD
      • Panasonic 5:1
      • A4 TECH multimedia combo keyboard
      • A4 TECH X6-20MD
      • Sonic-IT PU-303 PS3/x-box 360 combo joypad
      • HP DVD-RW
      • Windows 7 Ultimate 64bit
      • Not so good, but I still love it ^.^
      • 1mbps
    Aunee's Avatar
    May 2010
    বলবো না!
    perfect combo... just what i wanna say...
    খাই-দাই গান গাই, তাইরে নাইরে না!
    Quote Originally Posted by proton_chain View Post
    Man, I was joking, don't take it seriously.
    Btw, excellent post, double rep. given!
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Quote Originally Posted by Rion View Post
    I understand, I too think the post is too big to scroll.
    Thanks for the rep(s), much appreciated.
    To be really honest, this one is one of the best post I've seen in BG, IMO. So, giving rep. thrice isn't something big for this kind of work. Keep up the pace, PC!
    Reputation given tripple time.
    • Hamilton's Gadgets
      • Gigabyte H97 Gaming 3
      • Intel Core i7 4770 3.9Ghz
      • 16GB DDR3 1600hz
      • Nvidia GTX 1070 FE 8GB
      • Asus VS228N 21.5" Full HD.
      • Roccat Arvo
      • Cooler Master GX 650W.
      • 500GB
      • Windows 7/ Linux
      • 3DMARK Score, X2151.
      • Smile, BD.COM
      • 75KBPS(Variable)
      • 100+KBPS(Variable)
    Hamilton's Avatar
    ahh!! HDR
    here are some pictures, photos from Dhaka Motor Show 2010.
    @regarding Photomatix, if you don't register Photomatx, It'll show an irritating watermark in the middle.
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Quote Originally Posted by StoryTE||ER View Post
    ahh!! HDR
    Whoo! All of them are overdone! The top one looks excellent and artistic. All of them, especially the third one has very high noise in the bottom left corner and the girl's back (left). You could've used a noise reduction software to get rid of that. And why not post a somewhat "realistic" picture so that we could see what actually happened in the Motor Show?
    Thank you so much.
      • 16GB DDR3 1600hz
      • Roccat Arvo
      • 500GB
      • Windows 7/ Linux
      • Smile, BD.COM
      • 75KBPS(Variable)
    Hamilton's Avatar
    lol man, tbh, I didn't do it hehehe XD
    And there are hell lots of photos from Dhaka Motor Show, don't have much time i can post some HDR'd images here if you want that it
    nice tutorail man thnx
    Publisher
    • anik_lc's Gadgets
      • MSI B250M Bazooka
      • Intel Core i7-7700 Kaby Lake 3.6-4.20GHz 8MG Cache 7th Gen
      • 2x Corsair Vengeance 8GB DDR4 2400 BUS
      • Toshiba DT01ACA200 2TB SATA + 1TB Western Digital Blue
      • Sapphire Nitro + AMD RX 480 8GB GDDR5 OC
      • Samsung 21.5 inch Curved LED
      • Logitech H110 Headphone
      • Perfect CS-556 USB Keyboard
      • Delux DLM-137BU Optical USB Mouse
      • N/A
      • Thermaltake PS-TR2 600W 80Plus Bronze Power Supply
      • Power Guard 1200 VA
      • Windows 10 Pro
      • Very Satisfied
      • ICC
      • 300kbps
      • 400kbps
    anik_lc's Avatar
    Apr 2009
    Didn't notice before Proton Chain. Nice work. And agree with Rion. This is one of the best post in BG ever. So 4 ta repu.
    Like my Facebook page Gaming Newz for new gaming news updates.
    My Facebook Twitter YouTube Steam
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    Quote Originally Posted by anik_lc View Post
    Thank you very much, its my pleasure
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Effin awsum sig bhaiya :O! Beshi Awsum
    ~Awesome stuff .. i was kinda lookin for a thread to convert my images to HDR .. its one supercool thing when u work on pics wich needs blurs/motion blurs... it really does bring out real quality of ur visual =D~
    • iGx : Itachi's Gadgets
      • MSI Z270 GAMING PRO CARBON ATX LGA1151
      • Intel Core i7-7700 3.6GHz Quad-Core
      • G.Skill Trident Z 16GB (2 x 8GB) DDR4-3200
      • Western Digital Caviar Green 2TB and Samsung 850 EVO-Series 250GB 2.5" SSD
      • GEFORCE GTX 1060
      • ViewSonic VX2270Smh-LED Black 22" 7ms (GTG) HDMI Widescreen LED Backlight LED Monitor IPS panel 250
      • 7.1
      • Steel Serise Siberia V2 & Creative Inspire
      • CORSAIR K95
      • SteelSeries DIABLO + Fnatic Mouse Pad
      • PS3 Controller
      • CORSAIR CX 600
      • Asus DVD ROM RW+-
      • TV CARD, SCANER,Pendrive, wireless Headphone
      • "LIKES" Back-up to 45min
      • MICROSOFT WINDOWS 10 PRO
      • P1567 3DMarks 11
      • Physics Score 3131 ||Graphics score 1430
      • Local <3
      • 8.9MB
      • 6MB
    iGx : Itachi's Avatar
    Khilgaon,Dhaka
    such a nice post @proton_chain ...
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5" 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    r a ai post ta aage kgeyal kori nai.. @proton_chain awesome post man! time niye porte boshbo...
  1. Mid-Range Gaming PC @ 45K
    By ЯV●shafiee007 in forum Technical Support
    Last Post: January 7th, 2010, 16:37
  2. Vuze Beginners Guide
    By cRush in forum File Sharing and Torrents
    Last Post: August 18th, 2009, 00:59
  3. A Beginners Guide To DotA !!!
    By SP.Sn4k3y- in forum DotA Talk
    Last Post: May 21st, 2009, 21:00
  4. Sale (Used) mid range gaming pc
    By ЯV●@spret in forum Shop - Gadgets
    Last Post: February 12th, 2009, 23:34
  5. The age range of BG members
    By Tian in forum Miscellaneous Topics
    Last Post: July 27th, 2008, 00:01
Page generated in 0.34657 seconds with 15 queries.
