Results 1 to 10 of 10
Thread: Macbook Pro recovery help.
    Default Macbook Pro recovery help.
    My sister brought a macbook pro and asked me for help to fix it. Personally, I don't know anything about Mac and OSX. She said the person gave it to her told to press Command+R at startup, connect to wifi and do something from there which she didn't understand.
    After some inspection, it appears that the macbook is missing boot partition or the OS itself. After powering up, a folder icon with a question mark keeps flashing. If I go to recovery tools by pressing Command+R at startup, the only option is for connecting to wifi for internet recovery. When I select my wifi and put in the password, a spinning globe appears, with something loading which than goes away with an error message "apple.com/support -2105F".
    Can anyone with experience with Mac help me?
    Note: The Model is A1502 EMC 2678.
    Maybe it can't connect to the Wifi properly, trying removing the password and then connecting. I think what you are trying to accomplish is a fresh install of OSX. If that's the case then you can also do that through USB after downloading all necessary files.
    • shafi's Gadgets
      • Gigabyte Z170 gaming 7, apple macbook pro late 2013 retina/ apple ipad air/iPad pro 9.7 iPhone 7+
      • CORE i7 6700K WITH coolermaster hyper 212 evo/intel haswell i7 2.3 ghz
      • GSkill RipJaws v 3000 32gb ddr4/16 gb ddr3 1600 mhz on mac
      • Samsung 850 evo 250gb+1tb+wd ezex 1tb, trancend 35t3 3 tb, Wd black 5tb, 950 pro, muskin 1tb
      • gigabyte gtx 1080 xtreme sli/ intel iris pro+ nvidia gt 750m 2gb gddr5
      • samsung ku 6290 4k uhd tv, Dell S2716DG
      • Sound blaster zx
      • Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
      • corsair vengeance k95 rgb
      • logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
      • ps4, xbox one controller
      • corsair rm i 1000w
      • 32 gb trancend, 64gb sandisk, 16gb kingston
      • Windows 10 education, mac osx maverick 10.9.1
      • wei- cpu and ram-7.6 on stock, gfx-7.9
      • thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
      • Teksavvy 150mbps unlimited
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    If its late 2013(AS YOUR MODEL NUMBER SHOWING SUCH)like me u can connect it to your home wifi and let it do the recovery by itself.
    Quote Originally Posted by shafi View Post
    I've tried all type of settings for my WiFi router. WPA, WPA2, Open etc. Maybe there is some problem with my ISP (BDCom Smile). Can you suggest me where can I download the USB image for latest OSX?
    • shafi's Gadgets
      • Sound blaster zx
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    Well i would suggest you to try a torrent version of not the latest one, as yesomite causes some wi-fi issue, i myself am still on mavericks.
    After downloading it from torrent, (torrent is a lot safer according to me)install it and then update it to mavericks, and u r all set
    Btw while updating from app store u have to make sure that your net connection is un-interrupted, because a little disturbance on the connection will force the mac to download it from the beginning. To make matters worse, u won't get your full download speed while updating mac from app store.I don't know why the hell apple implement such non-nonsensical as well as rigid system but there's no other way round.
    Also another thing u might have noticed, but i didn't figure it out unless someone told me, is the left click button of your mac is actually the track-pad itself. U just have to push it a bit harder to make it work as a click-which can be later adjusted via preference. But first u need to donload mountain lion or whatever u can from torrent.
    Found this: Mac Os X Mavericks 10.9 bootable installer - 10.9 [Intel]. Going to try this one tonight. Thanks.
    I was also confused about not being able to just tap the trackpad to click like windows laptops. This one is actually the first macbook I've ever tried. But I'm not going to use the Macbook or any macbooks, just have to bring this one back to working order.
    • shafi's Gadgets
      • Sound blaster zx
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    Quote Originally Posted by aaz_swapnil View Post
    Glad i could help, enjoy your mac, macs are awesome for everything except gaming
    Just move to Yosemite directly, some of the Wifi issues have been addressed and should be completely ironed out by the next update.
    This should work fine: http://extratorrent.to/torrents/30400933/OS-X-Yosemite-10-10-1-14B25-bootable-USB-DMG-File.html
    And if you are not familiar on how to create the USB drive in Windows,
    1) Download TransMac, the trial version is enough.
    2) Connect your flash drive (8GB at least I guess(
    3) Open TransMac and Right Click on the Flash Drive
    4) Format Disk for Mac
    5) Right click again then Restore with Disk Image
    6) Select the DMG file.
    That should be all. Connect the USB to the MBP then hold Alt/Option key while booting.
    This should work fine: http://extratorrent.to/torrents/3040...-DMG-File.html
    I was planning to use PowerISO. Ok, now I'll try Yosemite and TransMac. Thanks.
    I'm not sure if PowerISO can do it, the USB needs to be in a special Mac format.
  1. Sale (New) surface pro 3 or macbook air?
    By Mohiuddin in forum Shop - Gadgets
    Last Post: November 25th, 2014, 20:14
  2. Sale (Used) Apple Macbook Air 11'' 64GB
    By error in forum Shop - Gadgets
    Last Post: November 23rd, 2012, 00:01
  3. Sale (Used) Acer Aspire ONE Netbook & Macbook Pro
    By ЯV●FireBaLL in forum Shop - Gadgets
    Last Post: August 11th, 2012, 13:36
  4. HP chairman caught using MacBook Air at home
    By salmanshah in forum Tech News
    Last Post: November 28th, 2011, 06:48
  5. My New MacBook Pro (Pictures)
    By Pyro.Dynamics- in forum Others PC Hardware
    Last Post: July 30th, 2009, 00:09
Page generated in 0.22594 seconds with 14 queries.
