Thread: need help for a sili prob..
    Default need help for a sili prob..
    sokol DL,Browsing bondho kore dayar poreooo amar dl speed 30-32 daykhay... and browsing spped slow hoiya jay,,, but kothay j ki dl hoitasee bujtase na...
    • 61ZONE's Gadgets
      • GIGABYTE GA-H55M-S2H
      • INTEL core i5 650 3.2ghz
      • 2+2 gb ddr3 1333mhz transcend
      • 500gb sata samsung F3
      • It's dead :(
      • LG 1953T 18.5 1360X768
      • Creative 2:1, a4tech HS-800
      • A4tech
      • A4tech x2
      • normal PS2 like controller
      • value top 500w
      • 22X DVD R/W Samsung
      • TRANSCEND 8gb+ apacer 4gb
      • WINDOWS 7 64 bit
      • Ja ase tai valo :D
      • Fibernet
      • Direct 32-40, Torrent 16-24
    61ZONE's Avatar
    A Mental Treatment Center Near Your Location
    Default Re: need help for a sili prob..
    I am also confused as u are. Bring task manager (ctrl+alt+del) to see any unuseal prog. running
    • HeLL]deathknight's Gadgets
      • Gigabyte HA-65-UD3H-B3
      • Core i5 2.91 Ghz Gen-2
      • Twinmoss DDR3 1333mhz 4GB
      • Samsung 500GB
      • ASUS GTX550 Ti
      • Philips CRT 17inch
      • Realtek HD 7.1 Channel,SteelSeries
      • Suntec Headphones/SteelSeries Siberia V2
      • A4Tech Slim Black
      • SteelSeries Sensei
      • Gigabyte 550Watt
      • Windows 7
      • Enough for me !
      • FusionBD/Link3 Technologies
      • 120KBps/196KBps
      • 50KBps/200KBps
    HeLL]deathknight's Avatar
    probably virus,get a good anti virus
    Using Bitdefender..... i m sure there has no virus in my pc. and i also run the task mangr but i did't understand wht's going on ????
    • Rumen's Gadgets
      • Gigabyte GA-EP45-UD3RL
      • Intel Core 2 Quad Q9400 2.93 ghz(OC)
      • 3 GB 1333 mhz DDR3
      • Samsung 320 gb HDD
      • Xfx 5850 1 gb DDR5 BLACK edition
      • Samsung 2243 1920x1080 HD LCD monitor
      • built in Realtek
      • Cosonic CD-721MV
      • xbox 360 controller
      • Coolermaster 600 watt ati xfire certified(italy)
      • ASUS 16x DVD Rom
      • 2 and 16 GB Pendrive
      • Name onek boro, lekhte parbona
      • Windows 7 nd xp
      • 7.1 in Windows 7 index(sometimes 7.2)
      • 2009-2013 porjonto valo vabe game khelte parlei hoy.
      • SMILE
      • 30-35 kBps normal and 200kBps-7MBps from local torrents.
      • 30-40 kBps normal and 150-500 kBps from local torrents
      • 9
    Rumen's Avatar
    Azimpur
    Windows update gula bondo kore dekhte paren.
    Anywhere Anytime Anytask
    Nothing but Excellence
  1. prob running 1.6 with vista
    By ЯV●VenDeTTa in forum CS 1.6
    Last Post: October 11th, 2009, 14:05
  2. KIS Prob
    Last Post: May 17th, 2009, 18:37
  3. prob accessing BG
    Last Post: November 19th, 2008, 01:32
  4. prob playing CS 1.6
    By saadbillah in forum Counter Strike
    Last Post: November 7th, 2008, 21:06
  5. 1.3 Lan PROB
    By Ic3_STrik3R in forum Older NFS Games
    Last Post: September 17th, 2008, 18:12
Page generated in 0.17518 seconds with 14 queries.
