Results 1 to 12 of 12
Thread: Problem with New HARD DRIVE.....
    Jun 2010
    Kazipara
    Default Problem with New HARD DRIVE.....
    Amar purano (p-3, Mobo Intel er 815) pc er jonno akta New hard disk (Samsung 80 GB IDE) kinlam ajke..Basay ashe XP setup dilam but Partition korar por XP install dile C: drive format chay (Jeta savabik) BUT drive format hoy na,,,,, nicher message ta show kore...
    ""Setup was unable to format the partition. The disk may be damaged.
    Make sure the drive is switched on and properly connected
    to your computer. If the disk is a SCSI disk, make sure your SCSI
    devices are properly terminated. Consult your computer manual or
    SCSI adapter documentation for more information.
    You must select a different partition for Windows XP.
    To continue, press ENTER.""
    Keu ki help korba????
    Default Re: Problem with New HARD DRIVE.....
    Quote Originally Posted by zaman_177 View Post
    Amar purano (p-3, Mobo Intel er 815) pc er jonno akta New hard disk (Samsung 80 GB IDE) kinlam ajke..Basay ashe XP setup dilam but Partition korar por XP install dile C: drive format chay (Jeta savabik) BUT drive bormat hoy na,,,,, nicher message ta show kore...
    Hard disk to BORMAT howar kotha na. Format howar kotha
    jai hok, partition ta delete kore notun partition kore dekhte paren.
    Jun 2010
    Kazipara
    Hard disk 3/4 bar full delete kore abar new partition kore dekchi but kono kaj hoy nai.....
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    check in bios whether AHCI mode is enabled or IDE mode. XP doesnt natively support AHCI and u need drivers for it.
    Jun 2010
    Kazipara
    Ki re vai BG te ki amon keu nai je amon problem face kore nai????
    Bohut ase
    ok wait, it's only 4 hours.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Are hai IDE abar AHCI hoi naki...oitato sata er ekta properties...
    Arekta kotha HDD noshto kina dekhen....ar arekta kaaj o korte paren....onno ekta PC te lgaia tarpor format hoi naki dekhen...na hoile Low Level Formatting kore dekhte paren...tao na hole HDD ta noshto....Warranty te pathan..
    Jun 2010
    Kazipara
    hdd ta onno pc te dia sundorvabe xp setup dilam.
    And oitar hard drive aitay diya xp dilam
    tahole ki mobo hd support kortese na.
    Btw duitai samsung er 80gb
    amarta SP0802N and oita SP0822N
    Ki kora jay?
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    mobo abar hdd support korbe na ken?...problem ta jotl...:S
    Ki ar kora apatoto swap korei chalate hobe...
    • |-<NOSALIS>-|'s Gadgets
      • Gigabyte GA-X58A-UD3R
      • Intel Core i7 930 2.8Ghz. LGA1366 Bloomfield with 8MB L3 Cache and 4.8GT/s QPI
      • 3x2GB Team Elite 1333Mhz. Performance RAM in triple channel
      • Samsung Spinpoint 160GB SATA II HDD
      • Spaahire Radeon HD 4890OC 1GB GDDR5
      • Samsung T220 22" LCD
      • Realtek 8-channel HD Audio
      • Microlab TMN-4 4:1
      • Perfect Multimedia
      • Dell Laptop Mouse 800Dpi
      • Clone PS2 Controller
      • Corsair TX650W PSU
      • ASUS 20X Dual-Layer DVD-Burner with LightScribe; Lite-on 16X DVD-ROM
      • Transcend StorJet C 500GB & WD Elements 160GB
      • Well 1200VA Generic
      • Windows 7 Enterprise 64-Bit
      • Windows Experience Index: 5.8(HDD); rest are 7.5+
      • Too much for me!
      • Mango TeleServices
      • 40-50Kbps
      • 40Kbps
    |-<NOSALIS>-|'s Avatar
    Jan 2010
    Mirpur, Dhaka
    Pretty rare and critical problem though. I had a problem with my old Celeron PC (a.k.a. Homeserver) but nothing like this. That PC could not detect 500GB SATA HDDs when connected to the SATA add-on host card. The problem was solved when I disconnected all the IDE devices. But your problem is really something else.
    • Manzoor's Gadgets
      • Intel PM45
      • Core 2 Duo [email protected]
      • 2GB DDR3
      • Toshiba 320GB
      • ATI Radeon HD4570
      • 14&quot; LCD @ 1366*768
      • Realtek HD Audio
      • Synaptics Multitouch Pad / A4 Tech XL-747H
      • A cheapo Chinese one
      • Transcend StoreJet 80GB
      • RahimAfrooz 1000VA
      • Windows 7 x64 / Ubuntu 10.04
      • Windows Experiance Index - 5.0 (Windows7)
      • Toshiba L510-S4314
      • Smile Silver
      • 20~25Kbps
      • 10~15Kbps
    Manzoor's Avatar
    A lot of old mobos can't detect drives larger than 38GB due to some limitations on their BIOS. You's case might be something like that. You can try these,
    1. Replace the IDE cable
    2. Set the hdd to 38GB limit (There should be a jumper for that on the HDD).
    3. Flash the BIOS (Risky but worked for me multiple times).
    You never fail until you give up...
    • avas911's Gadgets
      • OCZ Vertex 3 120GB Sata III &amp; Samsung 103SJ 1 TB F3
      • Philips 107S7 17&quot; at [email protected]
      • Transcend 500 8GB &amp; Corsair Survivor USB 3.0 16GB &amp; Samsung Class 10 16GB mSDHC
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    i think he said he can run another 80gb hdd fine.....so it cant be a 38gb limit/LBA problem....
    And the LBA problem is really old.....like pentium mmx/II kinda old......i have never seen a mobo that cant address LBA...
  1. Hard Disk Problem
    By dying4004 in forum Technical Support
    Last Post: August 12th, 2010, 00:09
  2. Problem with my new hard drive,,,
    By zaman_177 in forum Others PC Hardware
    Last Post: July 17th, 2010, 11:06
  3. Replies: 5
    Last Post: July 1st, 2010, 19:09
  4. Replies: 12
    Last Post: May 23rd, 2010, 04:14
  5. Replies: 0
    Last Post: October 14th, 2009, 23:22
Page generated in 0.23161 seconds with 14 queries.
