Results 1 to 18 of 18
Thread: [help] case fan header...
    • rabbyx7's Gadgets
      • Gigabyte GA-B75M-D3H rev1.1
      • Intel Core i3 3220 3.3ghz
      • A-Data XPG 1600MHz DDR3 4x 2GB = 8GB
      • Western Digital 500GB 7200rpm 3gb/s; Western Digital Cavier Blue 1TB; Transcend 500GB USB 3.0
      • SAPPHIRE HD 7870 2GB GDDR5 DUAL-X OC GHZ EDITION
      • Sony Bravia 32inch FULL HD LED; Asus VX229h 21.5 FULL HD IPS
      • REALTEK HIGH DEFINITION
      • Thermeltek Esports Shock Spin Blazing Red
      • MERCURY 8X00
      • SKYTECH
      • Xbox One Wireless Controller
      • Cooler Master V550 550W 80+ Gold
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • Windows 7 64bit Ultimate
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    Default [help] case fan header...
    So couple of days ago I bought a Corsair Carbide Spec -02 case which came with a front led 120mm intake and a 120mm exhaust rear fan. The problem is that both fans have a 3pin connecter and my mainboard, a GA-B75m-D3h rev 1.1 has only one 3pin connecter(sys_fan) That's where I connected the front led fan, but what can I do to connect the rear exhaust fan which also has a 3pin connecter? Someone advised me to get a 3pin to molex connecter. So i went to IDB and searched literally every accessory shops but couldn't find it anywhere! as if its non-existent!
    So is there any other possible way to connect my rear exhaust fan? Or do you know any other shops which has this 3pin to molex converter or something?
    thanks in advance
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    yeah you will need 3pin to molex connectors
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    Quote Originally Posted by [email protected] View Post
    any idea where can i find them...which shop?
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    it's supposed to be available in idb. why dont you try multiplan? there is a shop specialized in this kind of product.
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    which shop bro? I'll go to multiplan tomorrow...
      • Fiio Andes E07K
      • Corsair RM850
      • Windows 7 64Bit
      • It works!!
      • 154
    i forgot the name. but you wont miss it. most probably third floor. you will recognize it just by the display. sorry.
    Anyone who has some Thermaltake fan might have those stuffs laying around in thr house
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    My friend has couple of them but those connectors are 2pin to psu molex....my fan connector is 3pin... :/ think the best bet is to search multiplan tomorrow...
    Quote Originally Posted by rabbyx7 View Post
    you can use two pin converters if you can fit them. The third pin is only for speed monitoring, which you won't be using anyway when connecting directly to PSU. If you are hacker enough you can just cut of the connector and carefully trim and insert the open wires into PSU molex connectors, as I used to do with 80mm fans extracted from old PSUs.
    I might have some, and u should put that 2 pin with 3 pins
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    I searched the whole lot of multiplan without any success... :/ I bought 2 Tt thunderblade yesterday (1800rpm) and bothcame with their own 3pin to molex connector... my rear case exhaust fan is still out of order though
    I searched the whole lot of multiplan without any success... :/ I bought 2 Tt thunderblade yesterday (1800rpm) and bought came with its own 3pin to molex connector... my rear case exhaust fan is still out of order though
    Can u post pictures of all the connectors? I can do some mods if u want to make it work.
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    couldnt get on with things due to semester final but finally pulled things off today. so i did some googling and i took the header off from the case fan cable which had 3 wires and then cut a small portion of the sleeve from my upper exhaust fan and took turns to connect the wires and powering up to see whether the fan spins or not (i dont have a voltmeter ) and so finally its now working! two intakes and two exhaust all running at full speed!
ID:	35373   Click image for larger version.
ID:	35374   Click image for larger version.
    Hopefully u have connected the 12V to the fan, anyway if u have soldering iron u should solder the wires. Btw congratulations
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    ya the molex that came out of the psu is +12v ! what im wondering is i connected the +ve and -ve.. but what is the 3rd wire for? its not connected to anything so i just duct taped the open end. and no im afraid i do t have any soldering iron :/ maybe ill have a look for it?
    and thanks
    and thanks
    That's probably for sensing the speed, u don't need that anyway.
    Yeah its better to have one, cheap but handy
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    one last thing, since 3 of my 4 fans are directly connected to the +12v rail oc my psu, all if them are running at full speed right? is that a problem? i mean does that affects the fans in a negative way in the long run?
    so far I have only seen a non brand 12cm fan dying so it shouldnt be a problem. these are brush-less fans so only the chip might get burnt which is pretty rare.
  1. H81 mobos with internal usb3 header
    By Minhaj.Tahsin in forum Motherboard
    Last Post: August 8th, 2014, 06:12
  2. Front panel USB header replacement
    By limaj in forum Others PC Hardware
    Last Post: July 27th, 2014, 23:37
  3. Want to Buy Case Fan
    By redwan hasan in forum Shop - Gadgets
    Last Post: August 15th, 2013, 15:38
  4. Replies: 1
    Last Post: August 29th, 2011, 13:45
  5. Anime Header tutorial by InFn-0 : PSD file included :)
    By CoB666.InFn-0 in forum Programming
    Last Post: June 17th, 2008, 18:24
Page generated in 0.32759 seconds with 15 queries.
