Results 1 to 2 of 2
Thread: Good quality budget parts: CPU coolers and case fans
    Default Good quality budget parts: CPU coolers and case fans
    Hi folks
    I want to know whether and where you guys go looking for PC components these days. I have been importing stuff from Amazon all this while for almost 3 years, but it gets annoying sometimes especially because I have to rely on others. I like physical stores, or at least, some decent accessibility to warranty and service centres. I think the state of things have improved a little all these years.
    Previously, I could not locate a good and comfortable place where I could procure electronic parts for hobby purposes. Now, I have been made aware of TechshopBD, which looks awesome (though, because they still import stuff I'll end up paying a bit more than if I were to buy from Amazon through a proxy). I'm looking for a similar place, but for computer geeks (and also bookworms, while we're at it).
    I am presently looking for budget CPU coolers/HSF and case fans, [1][2][3][4] and optionally some toothpaste. [5] A search for "bangladesh cpu cooler" gave me some results, [6][7] but I have no experience buying from these places. I'd like to just stop Googling if someone could kindly point me to the right place or put me back in Amazon
    Thanks beforehand for any replies.
    [1] Arctic CPU cooler
    [2] CoolerMaster CPU cooler (for Intel socket LGA 775)
    [3] CoolerMaster 92mm case fan
    [4] Antec 92mm case fan
    [5] Zalman thermal grease
    [6] http://www.bdcost.com/Cooling+Produc...ooler%3AArctic
    [7] http://www.bdstall.com/listingDetail/index/10518/
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    about 2. u can look into binary logic. they bring cooler master stuff. cm hyper 212x(~3k) and 412slim(4k) both support lga 775 and are good bang for the buck.
    they also bring thermal grease and fans but don't have the exact ones that u want.
  1. 140mm Red LED case fans in Bangladesh
    By Rawkill in forum Others PC Hardware
    Last Post: April 5th, 2013, 14:17
  2. about case fans
    By codename5302 in forum Help - General Shopping
    Last Post: April 28th, 2012, 07:13
  3. Loud Case Fans any solution?
    By Rakin the Devil in forum Technical Support
    Last Post: March 19th, 2011, 03:00
  4. Suggest parts for a low-budget PC
    By Dee in forum Technical Support
    Last Post: November 24th, 2010, 01:33
  5. Searching Case Fans
    By craNIUM in forum Others PC Hardware
    Last Post: July 3rd, 2009, 11:02
Page generated in 0.15891 seconds with 14 queries.
