Thread: No audio from system
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Core i3 530 @ 2.93Ghz
      • 2gb DDR3 Twinmos 1333 and Transcend 4gb 1333
      • Samsung HD502HJ
      • Sapphire HD7750 1gb DDR5
      • LG Flatron W1953TE 768p
      • A4 Tech KR-83
    Nov 2012
    Nowhere, Oklahoma, United States
    Default No audio from system
    I recently OC'ed my i3 530 on a intel dh55hc mobo and this problem began. There is no audio input or output to and from the system. The playback devices menu shows audio being played on the green bars but there is no sound on the speakers even on their max. Headphones and earphones too.
    Fixes I've tried include: The disable front panel audio---> No such option even on drivers downloaded from manufacturer
    Disable front panel audio from BIOS ---> Nope!
    Disconnecting front panel from mobo---> NOPE!
    Flashing BIOS----------->NOPE!NOPE!NOPE!
    Device Manager uninstall>restart -----> NEGATIVE!
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    volume icon e ki red kono symbol dekhai ?
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    Nah. Softwarewise kono audio problems nai. But kono sound hoi na
    default output device ki? Speaker or digital receiver dekhay?
    There can always be some settings or software issue hidden somewhere. But also, there was also a case that I know of. One of my friend had developed similar issue, every bit of sound related software reporting the audio is playing OK, but there was no output on any of the audio jacks. And when after clearing motherboard CMOS and doing a fresh install of windows couldn't fix it, he claimed warranty replacement for the motherboard. The new motherboard worked ok for about 4 months and developed same problem again. Then 7 motherboard (various issues, not only audio) and 1 GPU warranty replacements later, he replaced his Fortrex 600watt PSU, and lived happily ever after.
    • _batman's Gadgets
      • msi Z87-GD65 inside Corsair Carbide 300R Windowed Edition
      • Intel Core i5 Devil's Canyon with CM Hyper 212X
      • G.Skill TridentX 8GB DDR3
      • Transcend SSD720, WDC20EZRX, WDC 10EZEX, WDC 5000AAKX
      • msi gaming x rx480
      • Viewsonic VX2270S 21.5'' IPS LED + Philips
      • Realtek ALC 1150 with Creative SBC
      • Piston 3 (Dead), Iron Ring Pro, Iron Ring HD
      • Logitech K120, Blackwidow X Chroma
      • Bloody A6, Logitech M557
      • Xbox 360 (Dead)
      • CM V650 Semi-Modular (80+ gold, active PFC)
      • Asus
      • WD My Passport, My Passport Ultra
      • Powerguard 1200 volt-ampere simulated sinewave
      • Win 7 Ultimate 64-bit / Windows 10
      • So... many... X
      • ~500KBps
      • 1/2 of download
    _batman's Avatar
    Jun 2013
    Umm, am I the only one who think this may be an hardware issue?
    • IMNOPRO's Gadgets
      • Intel DH55HC
      • Samsung HD502HJ
      • A4 Tech KR-83
    Nov 2012
    @aaz You maybe onto something. My PSU is a Tt 750W PSU. @Fox Dutai try korsi kam kore na.
    • akk's Gadgets
      • MSI G 41 P33 Combo
      • Intel Core 2 duo E 8400 3.00GHZ
      • Transcend 4 GB DDR 3 1600BUS
      • WD Caviar Green 2 TB
      • XFX ATI RADEON HD 4650 1GB
      • Samsung 18.5 IN LCD TFT (WIDE)
      • Realtek Built IN
      • 1.Perfect 5.1 +2 Sony Speakers Customized 7.1 & 2.A4 Tech HS -100
      • A4tech AntiRSI Multimedia+Logitech K200
      • A4 Tech+Logitech
      • 2 Dilong PU -305, Dilong 401T & A.tech dual vibe
      • DELL 300Wx2
      • Asus 52x DVD RW multispeed & multilayer compaitable
      • Prolink USB Modem(T&T)
      • apollo 650 VA
      • Windows 7 x64 Ultimate
      • 6.6 out of 7.9
      • Works Fine
      • Royal Green Online
      • ~34 KB
      • ~ 20 KB
    akk's Avatar
    If you havent tried it :
    first:install latest mobo drivers from https://downloadcenter.intel.com/Sea...42&ProdId=3142
    second:install all the drivers again.if installed reinstall again.btw while you are doing it remove all peripherals from your pc(unnecessary usb,audio connector etc.)
    third: flash the bios version your motherboard came with.
    fourth:remove front panel audio connectors from motherboard.
    fifth: In bios load fail safe defaults.
    sixth:go to windows.run the system for some time.
    seventh: plug in the head phone . test
    Quote Originally Posted by IMNOPRO View Post
    I'm not saying that your PSU might be the cause here. I'm just saying your motherboard's audio chip might be fried, as happened to my friend. For him, it was caused by the psu, but the actual cause for your case might be different, if your chip is indeed damaged.
  1. audio books
    By rayarnold in forum Member Central
    Last Post: October 19th, 2014, 16:31
  2. My Little Car Audio Upgrade
    By Rakin7 in forum Miscellaneous Topics
    Last Post: November 29th, 2011, 15:19
  3. Realtek HD Audio 2.64 Audio Driver
    By Frank3nst3in in forum Software
    Last Post: August 20th, 2011, 05:13
  4. Realtek HD Audio 2.62 audio driver
    Last Post: June 23rd, 2011, 23:30
  5. Realtek HD Audio 2.60 audio driver
    Last Post: May 8th, 2011, 18:45
Page generated in 0.20473 seconds with 14 queries.
