Thread: Need Urgent help !!!!!!
    Aug 2014
    Sylhet
    Default Need Urgent help !!!!!!
    How is Corsair VS450 as a low budget PSU.
    http://pcworldrajshahi.com/36/PC-Har...0#.VGiMRxBtaUk
    And one question more ___Is it reliable considering it's price??
    Thanks
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Intel Core i5 2310 (2.9 Ghz)--Stock Clock--Stock Fan
      • PQI-4gb-1333 Bus-single stick.
      • SAMSUNG Sata-2 (320gb)
      • Gigabyte 660-OC-2GB-Windforce2..
      • Samsung B1930-LCD-18.5 inch :(
      • Built in.
      • Creative Inspire T3200 (2:1)
      • Value Top-normal (multimedia)
      • A4tech X7..
      • Thermaltake Smart 550w- Modular
      • Samsung Writemaster-- Not using currently -_-
      • Apacer 8gb Pendrive-usb2-_-
      • Prolink-650VA
      • Windows 7-Ultimate-64bit
      • Gaming is fun, but Acquiring a Satisfactory setup for it is not -_-
      • 190kpbs
      • Havn't checked yet!
    -RAKIB-'s Avatar
    Jan 2013
    1. Good
    2. Yes
    N.B. ^ These factors depends on ur system, if u mention components of ur pc it will b easier to suggest..
    Why so Serious!
    Aug 2014
    Sylhet
    I will upgrade my pc fully after some days that's why I haven't posted any config.May buy i3 or i5(4th generation)[which 1 not sure now,depends on arranging budget] , have 1 TB HDD .
    Also buy mid range Graphics Card [less than 15k]
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    It should b okay for i5 and gpu<15k..
    Why so Serious!
    Quote Originally Posted by rOY_0 View Post
    Thanks
    It is 3.2k actually. You can buy in that price from IDB. No need to buy it from rajshahi. lol
    Aug 2014
    Sylhet
    Bro ,I'm from Sylhet and I'm not able to buy it from IDB[go to dhaka to buy a PSU!!!!!!!!!!!!!!!!!!!]. But I'm not gonna by it from PC World Rajshahi too.
    I will buy it from a local shop with full 3 years replacement warranty.But the price will remain same.
    Thanks.
    Quote Originally Posted by -RAKIB- View Post
    Thanks bro.
    BTW, you live in Sylhet ,bro?
    Thanks.
    Power Supplies do not have more than 2 years warranty in our country.
    Aug 2014
    Sylhet
    no!!!!!!!!!!!!!!!!!!!!!!!!!!
    But the shop owner said me that.He may made a mistake.
    2 years warranty is enough for me bcoz I don't think I will be using this PSU after 2 years.
    • -RAKIB-'s Gadgets
      • Asrock B75M
      • Built in.
      • A4tech X7..
      • Prolink-650VA
      • 190kpbs
    -RAKIB-'s Avatar
    Jan 2013
    Thanks bro.
    Yes, in syl now
    Why so Serious!
  1. gpu within 7/8k [urgent]!!
    By mr_08 in forum GPU
    Last Post: April 19th, 2012, 14:33
  2. Urgent help
    By shafi in forum Help - PC Buying
    Last Post: September 20th, 2011, 23:27
  3. Need urgent help.
    By kabir_sharif2000 in forum Technical Support
    Last Post: July 22nd, 2009, 00:10
  4. need urgent help!!!!:(
    By virus_bd in forum Software
    Last Post: May 17th, 2009, 04:14
  5. Need help abt GPU(urgent)
    By Red Devil in forum GPU
    Last Post: April 24th, 2009, 12:06
Page generated in 0.20686 seconds with 14 queries.
