Results 1 to 2 of 2
Thread: Need help :(
    Default Need help :(
    ame akta Tv card kinse...usb tv card.. but oita (xp to vista) supported... but ame win 7 use kore... tai ame 2 ta os aksathe use kortese.... xp only for tv card.. and win 7 for rest of work.. ame xp drive C tay first and win 7 drive D tay setup korse... but now amar tv card ar kaj thekee hochee but win 7 a game onk slow choltase.... ame age PES 10 full detail a kheltam easily .. but now low detail a kheleoo game onk slow chole... how can i solve this prob with my tv card and my win7 and GAMES...... HELPPPPP!!!!!!
    • shoshe's Gadgets
      • Gigabyte Z77 D3H
      • G.SKILL Ripjaws Series 8GB (2 x 4GB)
      • WD cavier blue 320gb, Samsang F3 1Tb
      • XFX AMD Sapphire HD 7790 Dual-X OC
      • Asus VX229H
      • Altec Lansing Octane 7
      • B110 Turbo
      • Bloody V9C
      • Logitech rumble pad 2
      • Cosair VS450
      • Asus dvd rw
      • Applow
      • Win 7 x64
      • BDCom Smile (silver)
    shoshe's Avatar
    Default Re: Need help :(
    i feel sorry for you.
    its cause one of my friend a lot of trouble to run both os(both are 32 bit) simultaneously.
    but as you have done it successfully so congrats.
    if your d drive is free with 5~6 gb then i don't see any problem.
    but my suggestion is if you have 4gb or higher ram then try win 7 x64 version cause i personally using them for nearly 9 months without a problem.(beta version also for win7).
    but experts can tell you more.
    good luck.
Page generated in 0.14700 seconds with 13 queries.
