Hi, ppl of banglagamer forum... im minitt,
Im presenting u my 1st
custom made CPU water blockk which is now fully
operational. (after long time of hard effort ofcourse
CPU prescott 3.0ghz stock(200fsb) @ 3.7 ghz (3690mhz) (246 X 4= 984mhz )
Idle 46 C with WC (56 C @ stok HS)
MAX load 54 C with WC (76 C @ stok HS)
Motherboard Asus P5GPL (No integrated GPU)
i think motherboards without integrated GPU is more overclock friendly.
right now my main bottleneck is my DDR1 RAM :mad:
cant get past 3.7 as my ram cant handle beyond this....
but im happy with it...caz i used to OC at 3.6 and
issues like overheating. Now im running 3.7 without any
problem.
making this water cooler wasnt easy though becaz i used a
reconditioned CAR Fuel pump from DHOLAI KHAL for
1000/= taka and it didnt last last long( only 3 days)
I guess it was just a bad luck. MY 2nd Fuel pump seems
quite well. Running it for more than a week(24/7)
without any problem.
other than the pump i didnt face much of a problem
but iahve a plan to replace my current fuel pump with
something more durable. So, any suggestion regarding PUMP
is greaty appreciated.
