Results 1 to 13 of 13
Thread: Need to learn about power consumption
    • yahyasharif's Gadgets
      • gigabyte 990 fxa -ud5
      • AMD fx - 8120
      • ADATA 1600 Mhz 8 x 2 =16 GB
      • Wesstern Digital cavier green 2 TB Maxtor 250 GB
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • A4 tech bluetooth keyboard
      • A4 tech bluetooth mouse
      • Cooler Master v750s vision 600 watt psu
      • Samsung external optical drive
      • a4 tech webcam;usb speaker
      • Windows 7 Ultimate
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Default Need to learn about power consumption
    what is the difference between 80+ gold , silver,bronze psu?
    what does the efficiency means in power supply?
    Does a 80+ gold psu consume low power?
    Will it reduce my electricity bill (such as : gold electricity bill<silver electricity bill<bronze electricity bill< normal 80+ electricity bill)
    And how much power does a psu consume in idle mode?
    Is there anyway i can know how much power my computer is consuming without using a watt-meter or any other electronic device??power
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
      • &#8734;
    Sybaris Caesar's Avatar
    Nowy Warsaw
    As for electric billing: gold > silver > bronze
    but not that noticeable for even caring.
    efficiency: 85% efficient(80+ bronze/silver) means 15% beshi current lage rated wattage pete. bakita haraya jai as heat or something.
    watt-meter er bodole kisu benchmark soft use kora jay. but i think tara shudhu output dekhay.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    Quote Originally Posted by Sybaris Ceaser View Post
    that means ami 750 watt bronze psu kinle electricity bill aro kom asto ??
    taile ami gold use korbo ken ?
    ar arekta question idle situation e ekta psu koto power consume kore ?
    software khujchi but pai nai
    i think this explains best
    It really depends on what units you are looking at how long it will take to pay off, some units also barely miss the next level up so they may be a better value. Overall, each higher level is about 2 percentage points more efficient than the one below it at 20/50/100.
    Here is some quick math for you, lets suppose you have a 500 W power supply, a system that pulls 250 W at full load, and is on 8 hour a day running at full load all the time(unrealistic but makes for much easier math), that puts your PSU at 50% load so its going to be at peak efficiency.
    Power drawn from the wall:
    Basic - 312.5 W
    Bronze - 304.9 W
    Silver - 294.1 W
    Gold - 277.8 W
    Platinum - 271.7 W
    That means that over basic you save 7.6 W/h with bronze, 18.4 W/h with silver, 34.7 W/h with gold, and 40.8 W/h with platinum. With 8 hours a day at full load that comes out to be 1.82 kWh, 4.42 kWh, 8.33 kWh, and 9.79 kWh saved per month with bronze, silver, gold, and platinum respectively. If you pay 15 cents per kWh that means that over the course of 1 year having a platinum rated PSU over basic saves you about $17.62 so it could take quite a while to pay for the difference with energy savings alone, but in general silver rated units and up are much better quality than basic rated units.
      • Asus vx229h ||Samsung 21.5&quot; S22A300B
    little off topic: too many bangladeshis think efficiency has something to do with power output... they think 80% efficient 650w power supply can give 650x80%= 520w dc power output at max
      • Samsung KS8000 55&quot;
    hmm..The correct calculation is a 80% effi PSU will draw 812.5watt from the wall to deliver 650watt.
    @yahyasharif u should stop worrying about psu effi and electric bill since the savings is very minor compared to the additional cost of getting a higher effi PSU.
    But one advantage of highly efficient psu would be it will be less hard on the ups when used for long duration.(assuming it's internals are smart enough to keep the inrush current draw as low as possible and comes with decently sized primary caps)
    But PSU effi also suffers when its fed with simulated sine wave.
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    Yup. I had to explain that to a LOT of people -_-
    Quote Originally Posted by GalibTheGamer View Post
    i know the feel bro
    to op: unless you are a electricity bill nazi you should stop caring about the difference between bronze and gold and care more about ampere in +12v
    • NahyaN's Gadgets
      • Gigabyte H61M-S2V-B3/ Thermaltake Spacecraft VF-1 Chassis
      • Intel Core i5 2400 with Coolermaster Hyper 212 EVO
      • TeamElite 8GB (2 x 4GB) DDR3 1600MHz
      • Samsung 500GB (Primary)/ WD Caviar Green 2 TB (Storage)
      • Sapphire Radeon R9 380X Nitro
      • Samsung 19 Inch LED Monitor
      • AudioTechnica ATH-M40X
      • A4 Tech Multimedia Keyboard
      • Logitech G402
      • XBox 360 Controller
      • Delta 550w
      • LiteOn DVD-RW 22X
      • Transcend 250GB Portable HDD
      • Seren1ty gets the job done. Period.
      • Earth Telecommunications
      • ~2 Mbps
      • ~2 Mbps
    NahyaN's Avatar
    Feb 2009
    This review of the Corsair HX1000i might help you understand a little about power consumption.
    Its uses a power supply load tester thingy and shows the efficiency at various watts.
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    I don't think anybody thinks like that
    Quote Originally Posted by yahyasharif View Post
    dude trust me i get that a lot.
    • mithun12ka4's Gadgets
      • Gigabyte B75M-D3H
      • Intel Core i3-3220
      • Transend 4x2 Gb 1600Mhz
      • Western Digital Caviar Blue 1TB, Samsung Spinpoint F3 500 GB and Seagate Barracuda 3TB
      • Sapphire Radeon HD 7790 OC Dual-X
      • LG 22&quot; Class Widescreen LCD (W2243T)
      • FND 2.1
      • A4-Tech ComfortKey KR-85
      • A4-Tech OP-620D USB
      • Havit HV-G83
      • Corsair VS450
      • Mazeda
    Oct 2013
    So buy using a Gold PSU over a basic one would save me about 10 units a month, 120 units a year. I pay about TK8 per unit. So I will save around 1K in a year.
    I am wondering is it worth paying the premium?
      • Logitech G402
      • &#8734;
    Nowy Warsaw
    @Mithun 14ka4, not much. but efficiency begets longetivity. because unused energy translates into heat. and heat results to ..... saw some seasonic unit, x460 maybe. efficient enough to not needing a fan. perfect for HTPC, which to this topic is completely out of context -_-"
      • AMD fx - 8120
      • 7970 vapor x 3gb
      • Samsung S19D300NY
      • Cosonic
      • ZX online bd
      • 192-200
      • 100-200
    Apr 2014
    main reason behind posting this, i faced power failure and lack of electricity (due to prepaid balance) while using cooler master v750 (80+ gold)
    Quote Originally Posted by mithun12ka4 View Post
    yeah it saves a lot of unit
  1. What's the power consumption of this system
    By Cpt.Mactavish in forum Technical Support
    Last Post: November 23rd, 2013, 18:05
  2. Power consumption
    By gamer24 in forum CPU
    Last Post: October 20th, 2012, 01:15
  3. Computer Power Consumption and UPS Backup
    By Muhammad Zunaid in forum Technical Support
    Last Post: September 14th, 2012, 04:22
  4. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  5. Lets Calculte Our Pc's power consumption
    Last Post: November 21st, 2010, 01:31
Page generated in 0.26814 seconds with 14 queries.
