Thread: Weird Problem With Ethernet Controller
    Default Weird Problem With Ethernet Controller
    nothing!
    1st get a good grounding connection to save your components from surge.
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    permission problems maybe? few months back when i first got my router(tp-link 840n) i couldn't access a few sites. got to the connection properties and set up the DNS given by the isp. that solved the problem.
    about the drivers, u can install them in compatibility mode afaik.
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    Well, ami jokhon broadband er connection nei tokhon ekdin surge er karone amar mobo er built in realtek gbe lan controller ta noshoto hoye jai, tarpor ami tplink tf-3200 lan card ta use korte thaki, kintu etar problem holo je etar driver windows 8 or later version gula support kore na, tai baddho hoye windows 7 ei chalate thaki, tar kisu din por tplink wr720n router kini. router theke lan er jei connection ta ber hoi ota pc te lagale auto connect hoye jai, aladha vabe user id ar pass hoye connect korte hoi na, recently ami check kore dekhi je amar mobo er built in lan controller thik e ase -_______-
    kintu jokhon oitai router er line lagai tokhon net use kora jai na (yellow sign on network icon, saying limited connectivity, even router er admin panel eo dhuke na)
    kintu jokhon net er main line lagai ar id pass diye connect kori tokhon thik vabei net chole.
    Someone plese help me out....
    Note: Connection type- WAN (PPoE)
    mobo er built in lan controller holo Realtek RTL8111D
    Amar ek PC te same LAN card tai use kori windows 8.1 a.
    TPlink theke new driver download kore dekhte paren, akhon W8.1 er jonno alada folder thake driver er zip file a.
    Amar obosso oitao lage nai, Windows 8.1 nijei update theke LAN card tar driver download koreche.
    • RMS's Gadgets
    RMS's Avatar
    Sep 2011
    Thanks everyone for your valueable suggestions.
    Specially @RMS bhaiya, apnar method e windows 8.1 e ei puran lan card support korse. thank you very much for this (y)
    My pleasure.
  1. WEIRD Problem!!! Need Help
    By nafis087 in forum Technical Support
    Last Post: August 1st, 2014, 13:16
  2. Weird Problem = IDM
    By Uchiha Obito in forum Technical Support
    Last Post: November 27th, 2010, 18:20
  3. a weird problem!
    By Mohaan in forum Technical Support
    Last Post: June 19th, 2009, 13:49
  4. Weird problem
    Last Post: April 15th, 2009, 21:54
  5. Weird Problem
    Last Post: April 5th, 2009, 03:45
Page generated in 0.18803 seconds with 14 queries.
