Thread: USB Problem
    • Astro Boy's Gadgets
      • Gigabyte Sniper M5
      • Intel Core i5 4570 @ 3.20GHz
      • Corsair Vengeance 1600MHz 4x2= 8GB
      • HGST 1TB Internal SATA 3.0 + 1 TB 3.0 External
      • MSI R9 270X Twin Frozer Gaming - 4GB EDITION
      • ASUS MX239H
      • A4Tech H100
      • A4Tech Lighting KD 800 Keyboard
      • A4Tech USB Mouse
      • Cooler Master V 750W 80 PLUS GOLD
      • Asus 24x DL DVD R/W
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Angry USB Problem
    Any USB Connected Device Got Disconnected Randomly And Connected Again, Expect Mouse And Keyboard.Any Solution?
    Make sure the USB devices are functioning properly as well as the USB ports of the computer. Does this happen to all the USB ports? Alternatively open Device Manager and click on the Universal Serial Bus Controllers. See if there is any Yellow Exclamation Mark beside any of the USB icons. If so then try uninstalling them, restart the computer and scan for hardware changes; Windows will detect the USB ports and install drivers for them. Even if you don't find any YEM there, you can still give it a go and see what happens.
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    Exclusive 8.1 problem right? I have the same thing. There are some registry hack and other stuff on the internet. Nothing worked for me. The USBs can't power my USB modem constantly.
      • ASUS MX239H
      • A4Tech H100
      • A4Tech USB Mouse
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Quote Originally Posted by Cynical View Post
    Make sure the USB devices are functioning properly as well as the USB ports of the computer. Does this happen to all the USB ports? Alternatively open Device Manager and click on the Universal Serial Bus Controllers. See if there is any Yellow Exclamation Mark beside any of the USB incons. If so then try uninstalling them, restart the computer and scan for hardware changes; Windows will detect the USB ports and install drivers for them. Even if you don't find any YEM there, you can still give it a go and see what happens.
    Yes, All USB Port.
    Any No Problem With Universal Serial Bus Controllers.
    Quote Originally Posted by Frank3nst3in View Post
    Yes, It is 8.1 Pro.
    Then, What the condition of urs Now? Do you get Any Solution?
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    I couldn't use any portable HDD or USB modem. But I could connect phones fine. You can try some registry tweaks but they didn't work much for me. No, couldn't find any solution. Had to buy a router to connect the modem indirectly.
    I thought this was an AMD only problem.
      • ASUS MX239H
      • A4Tech H100
      • A4Tech USB Mouse
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Any Other Solution?
    • Ony's Gadgets
      • Gigabyte G1 snipper 5
      • Core i7 4770 with DeepCool Mini FS
      • 1TB HDD(WD) .128GB SSD(Kingston) . 1TB external HDD transcend,128GB Transcend SSD370 (As Live CD)
      • Gigabyte GTX 750 TI Windforce edition
      • Dell S2240L
      • Gigabyte G1 snipper 5 internal extreme sound card
      • Samsung Earphones (S4 version) Works fine for me.
      • A4tech Bloody b120 gaming
      • A4tech Bloody ZL5 core 3 Activated
      • PS 1 with adapter
      • Thermaltake Smart 530W
      • Asus 24X
      • 16 Gb JF500,16 GB JF710S, 1TB external HDD,
      • Apollo 1000 VA Offline UPS
      • Windows 7 64bit , Ubuntu 14.04
      • Nothing big, just a starter PC for extreme gaming.
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    Ami windows 7 ultimate use kori, nd amar o usb problem hoy. But shudhu case er usb plug e problem hoy but mobo r usb use korle problem hoy na and normal files e prob hoy na just 20-100 Gb er files external hard disk theke ana neoa korar time e hoy.
      • ASUS MX239H
      • A4Tech H100
      • A4Tech USB Mouse
      • BanglalionWimax
      • 1000
    Astro Boy's Avatar
    Sep 2013
    Quote Originally Posted by Ony View Post
    Amar to Sob port ei hoy
    Make sure you have a decent Ground aka Earth connection. If you already have ground connection make sure that the I/O shield is not showing any voltage reading when measured a multimeter. (u need to have multimeter)
    Dial your multimeter to AC range 1st
    then Connect black probe to Negative point of A/C outlet and then touch the I/o Shield with the red probe. If there is high reading. (anything higher than 2v is considered bad) u have a faulty ground connection.
    Optimal value should be 0 between Negative to Ground.
    or u can just try putting a 20 taka tester on your i/o shield. If the light wihtin the tester lights up then u have high voltage on the i/o. Which is not good.
    A ground connection is necessary as lots of circuit uses ground reference to transmit data. USB/ RS232/lan devices can have performance issues when u have bad ground connection.
  1. HDD Problem!!!
    By Shoaib in forum Technical Support
    Last Post: January 8th, 2014, 00:54
  2. GTA IV (FPS Problem)
    By Ghz in forum General PC Gaming
    Last Post: April 19th, 2013, 10:38
  3. Nvidia Driver Problem or Graphics Card Problem ??
  4. is anyone having this problem?
    By Speed in forum ISPros
    Last Post: March 4th, 2011, 17:44
  5. PSU Problem
    Last Post: May 13th, 2009, 03:57
Page generated in 0.20865 seconds with 14 queries.
