Results 1 to 19 of 19
Thread: Help need suggestions regarding psu
    Question Help need suggestions regarding psu
    Hi
    I am a new gamer and I want a suggestion. I bought my PC from Flora Limited and the casing says, "ATX Thermal Casing with original 450w PSU". I want to upgrade my PC and get a Sapphire R7 260x 2GD5 GPU. Do i need to buy a branded PSU or will the "origibal 450w PSU" do the job
    • Ony's Gadgets
      • Gigabyte G1 snipper 5
      • Core i7 4770 with DeepCool Mini FS
      • 1TB HDD(WD) .128GB SSD(Kingston) . 1TB external HDD transcend,128GB Transcend SSD370 (As Live CD)
      • Gigabyte GTX 750 TI Windforce edition
      • Dell S2240L
      • Gigabyte G1 snipper 5 internal extreme sound card
      • Samsung Earphones (S4 version) Works fine for me.
      • A4tech Bloody b120 gaming
      • A4tech Bloody ZL5 core 3 Activated
      • PS 1 with adapter
      • Thermaltake Smart 530W
      • Asus 24X
      • 16 Gb JF500,16 GB JF710S, 1TB external HDD,
      • Apollo 1000 VA Offline UPS
      • Windows 7 64bit , Ubuntu 14.04
      • Nothing big, just a starter PC for extreme gaming.
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    Bhai jodi casing er shathe PSU eche thake tobe apnake new PSU kinte e hobe. Casing er PSU 450 W likha thakleo ogulo mainly 300 W er e hoy.and GPU er safety r jonno new PSU lagano uchit. And ei reason e i bhalo casing e PSU thake na,Apnar choice moto lagiye nite hoy. Apni jehetu new gamer tai ekta bhalo PSU te invest koren. Apnar PC upgrade kora lagleo PSU ta r tokhon change kora lagbe na.
    • GalibTheGamer's Gadgets
      • MSI X370 Gaming Pro Carbon
      • Ryzen R5 1600 @4.0GHz
      • Gksill Ripjawas V DDR4 16GB 3000MHz
      • Samsung 850 EVO 2350GB
      • MSI GTX 1080 Gaming X
      • Philips 223V 21.5 inch monitor
      • Logitech K270
      • Bloody A9 (core 3 cracked :P )
      • Xbox One controller (Wireless)
      • EVGA G2 850W
      • A4-Tech PKS-732G Anti-glare WebCam
      • Windows 10 Pro 64-Bit
      • KC Network (3 Mbps)
    GalibTheGamer's Avatar
    May 2013
    R7-260X might work in your generic psu. But it's risky since the gpu can die anytime. You better buy a branded psu. What is your PC configuration?
    Quote Originally Posted by Azra3l View Post
    Hi
    YES. btw, post your specs here.
    i3 2100, 4gb DDR3(I'm adding 4 more). So I do need a branded PSU?
    My specs-
    i3 2100
    4 GB ddr3 ( imma add 4 more)
    Quote Originally Posted by Ony View Post
    Thanks bro
    My specs-
    i3 2100
    Thanks bro
    lagbe, tobe nvidia er 750 ta nile lagbe na.
    Better kunta?
    Better kunta?
    psu lage na emon gpu gular moddhe best holo, MSI N750TI 2GB GDDR5 OC edition ta, tai r7 260x na niye 750ti ta newai better. jei taka diye branded psu kinte hoito oikhane ekta bhalo gpu pawa jabe.
      • Logitech K270
      • EVGA G2 850W
    May 2013
    What's your budget actually?
    Overall R7 260x ki 750ti er cheye better?
    Quote Originally Posted by GalibTheGamer View Post
    15k PSU shoho
    15k PSU shoho
    taile psu laganor dorkar nai, ekebare MSI N750TI 2GD5/OC niye felen. 750 ti better.
    750ti is 16.5k :/ I can't go above 15k at all bro
    price outdated :v
    ar jodi ekebarei na hoi den non-ti nilei hobe.
      • Logitech K270
      • EVGA G2 850W
    May 2013
    If the budget is 15k, then you should definitely buy a R7-260X 2GB and a Corsair VS450 psu. R7-260X performs better than a GTX 750 and also performs almost the same as a GTX 750 Ti. Besides that, R7-260X also features TrueAudio and Mantle. And since your processor (i3-2100) is weak, the effect of mantle will be high, thus, you will get a high fps-boost in mantle-supported games
    And whatever you say, for a PC which will be under high stress (here, it's gaming), you need a branded psu for a more stable and a long-lasting PC.
    • Ony's Gadgets
      • Dell S2240L
      • PS 1 with adapter
      • Asus 24X
      • Delstar @ Eirtel
      • 512KB/s = 4Mbps
      • ^ in reverse
    Jul 2014
    @Azra3l apni HDD/SSD, Case Fans,USB devices, ittadir upor o PSU depend kore. And they are right. GTX 750TI is one of the most power efficient GPUs out thereIf you but GTX 750/TI you won't need a PSU. And if the GTX 750TI is over priced for you, you can go with the non TI version,as TI means that your card will come pre overclocked. So you can buy the GTX 750 and then overclock it your self and save that extra money.
    ok bro I'm taking your suggestion Thanks a lot
      • Logitech K270
      • EVGA G2 850W
    May 2013
    You won't be disappointed with that decision
    will 750ti bottleneck with i3 2100?
      • Logitech K270
      • EVGA G2 850W
    May 2013
    There will be no bottleneck
  1. Want to Buy Gpu. Need Suggestions.
    By Xel-Naga in forum Help - PC Buying
    Last Post: August 6th, 2014, 01:09
  2. Need suggestions about new PC.
    By cool.dx.rip in forum Help - PC Buying
    Last Post: February 13th, 2013, 13:32
  3. Suggestions plz !!!
    By ahmadrafi9 in forum Gaming Topics
    Last Post: July 18th, 2012, 00:39
  4. ISP suggestions plz..
    By banglabro in forum ISP
    Last Post: April 1st, 2012, 16:36
  5. Need Suggestions about SSD
    By CHR.Satiator in forum Others PC Hardware
    Last Post: May 31st, 2011, 01:59
Page generated in 0.29577 seconds with 14 queries.
