Thread: Need Urgent Solution of This Problem In C Language
    • Frankenstein's Gadgets
      • GIGABYTE GA-B75M-D3H (rev1.1)
      • Intel Pentium Processor G860
      • ADATA 4GB AD3U1333W4G9-R
      • Western Digital WD Blue WD5000AAKX
      • SAPPHIRE HD 7770 GHz Edition OC 1GB GDDR5 (v2)
      • ViewSonic VX2270S-LED
      • Creative SBS A235
      • COOLER MASTER GX 450W
      • ASUS DRW-24B5ST/BLK/G/AS
      • HP Deskjet 1000 Printer - J110a, Canon CanoScan LiDE110
      • PROLINK PRO700C 650VA
      • Windows 7 Ultimate x64 SP1
    Frankenstein's Avatar
    Jun 2012
    Default Need Urgent Solution of This Problem In C Language
    1 PROBLEM STATEMENT(S)
    Design and develop a console program to tell the day of the week of any date between 1900 to 2050.
    2 REQUIREMENTS
    (a)Your program will check the following:
    •The year is between 1900 and 2050.
    •The month is in the range 1 and 12.
    •The day is in the range appropriate for that month. For months other than February, the range of days will be from 1 to 30 or 31 days. The range of days for February is between 1 and 28 or 29 depending on whether the year is a leap year or not.
    (b)All of the ranges are inclusive. You will first prompt the user to enter the year and then check whether the year is in the range specified. If it is not, then you will keep prompting the user to enter the correct year. After that you will prompt the user to enter the month and run a similar check. Lastly, you will prompt the user to enter the day and run a check. For example, the input 29, 2, 2012 is valid, but the input 29, 2, 1900 is not, because 2012 is a leap year and 1900 is not a leap year.
    Sample session are as below:
    Enter year: 1960
    Enter month: 12
    Enter day: 12
    The day is Monday.
    Continue (y/n): y
    Enter year: 2014
    Enter month: 9
    Enter day: 12
    The day is Friday.
    Continue (y/n): n
    (c)You should design your program to perform the required tasks modularly and to in- crease code re-usability. Hence, your program should:
    (i)create one function for each activity ;
    (ii)make use of parameter(s) passing; and
    (iii)make use of return value(s).
    (d)Applying appropriate control structures to handle program logic in your program:
    (i)Includes at least two (2) different types of selection or multiple selection structure; and
    (ii)Includes at least two (2) different types of repetition structures
    • Syeef's Gadgets
      • WD 1TB Blue Sata III
      • Samsung 22-inch LED 1080p
      • N/A
      • Creative SBS 2.1
      • Tt eSports Knucker
      • Logitech F310 Gamepad
      • Samsung DVD-RAM 24x Sata
      • 650VA
      • ~15 Mbps | 128 KB/s
      • ~5 Mbps | 32 KB/s
    I don't think we should help him cheat or do his homework for him...
    Quote Originally Posted by Syeef View Post
    This isn't even close to cheating and you can always help with hw in a productive way, ie not just give the answer.
    There are official sites dedicated to homework help, (coursehero.com) even yahoo answers work for a lot of things.
    • Syeef's Gadgets
      • N/A
      • Creative SBS 2.1
      • 650VA
      • ~5 Mbps | 32 KB/s
    He posted entire question... saying, "Need Urgent Solution of This Problem" what else do you think it is?
    I've seen worse ways, this is pretty normal. Now if you want to help then help otherwise then just stay out of it.
    And stop the useless arguments guys (not pointing at you Syeef). Next OTs will get infractions.
    could be an exercise? he might not find any solution that's why posted here.............accusing for cheating is harsh without knowing the real reason from him
    check PM @Frankenstein.
  1. Dell Inspiron n5520 Webcam problem!! Need solution badly :/
    By QuadStorm in forum Technical Support
    Last Post: February 20th, 2014, 18:42
  2. Replies: 0
    Last Post: April 15th, 2013, 23:47
  3. Replies: 6
    Last Post: October 1st, 2009, 07:34
  4. [Solution] Problem playing WCG '08 demos
    By SenSeiFAR in forum CS 1.6
    Last Post: March 3rd, 2009, 06:06
  5. strange problem....any solution?
    By saadbillah in forum Older NFS Games
    Last Post: November 16th, 2008, 22:38
Page generated in 0.18764 seconds with 14 queries.
