Thread: Pendrive problem
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Default Pendrive problem
    so, the other day, when i plugged-in my pen drive in a laptop
    i didn't browse the contents of the pen drive from 'Explore'
    or 'Folder Options' i went directly inside(double clicking)
    from then on, i can't access the pen drive
    and i cannot even format it
    says that Windows cannot format the disk
    i've tried different PCs with different Anti viruses
    but nothing works and btw, the laptop didn't have any update anti virus
    since, most people uses pen drive
    i thought ppl might run into this problem
    and invent a solution to it
    help would be of great help plzzz....
    • Ra's al Ghul's Gadgets
      • Gigabyte MA78LMT
      • AMD FX4300
      • 4GB DDR3 1600Mhz
      • 160GB Samsung + 500GB Toshiba
      • Sapphire R7 250
      • Samsung 920NW
      • Creative Audigy 4
      • F&D 5.1
      • A4Tech regular
      • DiLong Gamepad
      • Thermaltake Smart 530W
      • Asus 16X DVD Rom + Samsung DVD Burner
      • Windows 7 64bit
      • 42-90
      • 24
    Ra's al Ghul's Avatar
    Jan 2010
    Default Re: Pendrive problem
    Can you give an exact screenshot or error message it shows while you try to format the removable disk??
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by Ra's al Ghul View Post
    thank u for ur reply
    pops out automatically after i plug-in the pen drive
    after i try to format it
    Jun 2010
    Kazipara
    Amaro akbar eirokom hoichelo pore "Low level Partition" dichi pore akkebare OK !!!
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Quote Originally Posted by zaman_177 View Post
    LOW LEVEL PARTITION kamne dae bhai help koren plz????
    accha you can try the HP Format tool, it was very good & formatted most of my stubborn pendrives!
    I hope this works:
    http://en.kioskea.net/download/downl...ge-format-tool
    Jun 2010
    Kazipara
    Asole oita Low level partition hobe na hobe "LOw level format". google e search dile onek soft paba jekono akta diye korlei hobe.
    Asole onekdin age korchi to tai soft er naam ta vule gasi.
    • Manzoor's Gadgets
      • Intel PM45
      • Core 2 Duo [email protected]
      • 2GB DDR3
      • Toshiba 320GB
      • ATI Radeon HD4570
      • 14" LCD @ 1366*768
      • Realtek HD Audio
      • Synaptics Multitouch Pad / A4 Tech XL-747H
      • A cheapo Chinese one
      • Transcend StoreJet 80GB
      • RahimAfrooz 1000VA
      • Windows 7 x64 / Ubuntu 10.04
      • Windows Experiance Index - 5.0 (Windows7)
      • Toshiba L510-S4314
      • Smile Silver
      • 20~25Kbps
      • 10~15Kbps
    Manzoor's Avatar
    If you have warranty then just tell them to replace it.
    You never fail until you give up...
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    i did LLF it
    thank u everybody
    whenever there's any technological problems
    u know where to count on
  1. Help, cant delete virus fom my pendrive
    By Arif69 in forum Technical Support
    Last Post: May 3rd, 2010, 01:09
  2. pendrive to HDD copy problem
    Last Post: October 15th, 2009, 23:10
  3. Replies: 7
    Last Post: September 27th, 2009, 10:54
  4. Use pendrive as ram !!!
    By cybervirus007 in forum Technical Support
    Last Post: September 26th, 2009, 23:37
  5. Want to Exchange a usable LENO Mouse (Optical) vs a Pendrive of Any Size
    By Mad Monk in forum Shop - Gadgets
    Last Post: February 7th, 2009, 01:43
Page generated in 0.20669 seconds with 15 queries.
