Thread: Best budget card without needing ext. Power supply?
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Default Best budget card without needing ext. Power supply?
    Sorry if I'm posting in the wrong section. I figured gpu section would get better suggestions.
    LOL, u didn't mention the budget
    Its the MSI N750TI TF 2GD5/OC, which doesn't need an ext. psu. But if you need something from amd its gonna be the R7 250, which is far away from that nvidia beast.
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    well i figured it can only go so high if external psu was taken out of the context..thanks for the suggestion.
  1. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  2. Replies: 43
    Last Post: February 12th, 2011, 20:19
  3. Replies: 21
  4. Best Power Supply
    By EBL.Mantis in forum Others PC Hardware
    Last Post: January 9th, 2011, 01:14
Page generated in 0.15831 seconds with 14 queries.
